Guest a31rb25
hey all im after a body kit for my ceffy but i cant find anything besides uras and vertex witch looks the same anyways.
can some1 help me out? were can i get something diffrent from, is there anything else available
ta ben
BN
Origin
Final Konnexion
Workshop X
Autech
GOOGLE!!!!!
is that site legit? the whole thing has just been copied (via a offline explorer program) from the jp site - and quite a bit is missing
My old Cefi had the only known Genuine Final K kit on it - either that or whomever else got one never showed it off on SAU :)
And that "http://www.finalkonnexion.com.au" isnt exactly listed on the FK Japan site as an official distributor for FK. I would be more inclined to use a reputable known genuine parts importer such as www.c-red.com.au - atleast I can vouch I got my kit from them and it was definately genuine!
http://www.sido-takushi.com/paintnpanel/Image013.jpg - genuine
Kit on - http://www.sido-takushi.com/paintnpanel/finalk/
Cheers
JK
yeah my bad, looks a bit dodgey, i sent them a fax though, just to see whats said, ill keep y'all informed if ya want? >_<
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
