I got the Z32 on my R33, came with it when i bort it direct from the importer, I didnt know it needed to get remap though,
hopefully mine was >_<
Still stock though
it would have to, otherwise your car would run like a dog
even though the q45 and z32 may be the same size (i didnt know that before), the q45 as far as i know can read more air flow so it doesnt max out as quickly as the z32.
https://www.sau.com.au/forums/topic/179028-airflow-meter/#findComment-3263628
yeah sorry typo on my behalf;
GTR 65mm
Nismo 65mm (z32 internals inside GTR shell)
RB20 80mm
RB25 Series 1 80mm - 4 wire - green label (same as RB20)
RB25 Series 2 80mm - 3 wire - pink label
Z32 80mm (same as RB20/RB25 for the bolt pattern, afm adapter and turbo duct, new plug)
Q45 90mm (different bolt pattern, needs new afm adapter and turbo duct or reducer, new plug)
https://www.sau.com.au/forums/topic/179028-airflow-meter/#findComment-3263924
GTR 65mm
RB20 80mm
yea thats it. i was wrong with my sizes! :thumbsup:
https://www.sau.com.au/forums/topic/179028-airflow-meter/#findComment-3264607
