Was about to start a new thread, but this might do.
I live in Cairns and obviously have a white GT-t.
More to the point, anybody know who the chick with the white GT-t is? Or the bloke with the clean grey GT-t? Want to catch up and get some pics of some R34s side by side.
  • Replies 100
There is a chick who drives a yellow R34 GT-T in the Woree/Bayview Area, also seen the girl driving the white one around every now and again. I also seen the Silver R34 GT-T on Australia day out near campus domino's, really clean looking R34. Was checking out the car till I suddenly realised that the guy must have thought I was checking him out and gave me a weird look, felt like a bit of a dickhead. There are also a few black ones running around.
I haven't been to a meet yet, so don't know many peoples names.
+1 for cairns. Moved here late last year. Keen for a cruise whenever. Look forward to the next meet. Have seen alot of very clean skylines around (and a few that deserve better owners :). Got a white gts-t, so will keep an eye out for fellow owners. Seen some very clean 34's getting around, very well kept rides. See ya's on the road.
Pretty sure I've seen you around, like a series 1 White r33? Whats your plates?
*** JIQ White wheels. Seen plenty up here. No one returns the wave though. Whats the best night to hit the road around here
Yeah I've seen you around. Thursday night is not a bad time to go for a drive out to the beaches (clears my head during the uni semester). Also if you think your the next Vin Diesel you can always hangout near Woree maccas, I do my best to stay away from there though too many 40-50 year old guys showing off their cars to 17-18 year old's when the should be at home with their wives and a lot of P platers showing of their '10' second commodores. Not my scene but different strokes for different folks.
Haha yeah I've had 2 people wave/nod back at me since Ive owned skylines. You give up after 20-30 unreturned waves. Makes you feel like a sped waving at someone and they look at you like 'who the f&*k is that' and keep driving without returning the wave.
  • 1 month later...
  • 3 months later...
Hey guys, so who's keen for a cruise? Couple people so far meeting up next sunday the 1st.
Head from Cairns up to port for a coast cruise. Good to see some new faces and some old ones. Maybe met a few people before.
  • 3 months later...
I'll be back in Cairns mid december if anyone's up for a cruise? Normally meet at smithfield, head up through mareeba, mt molly, and down via jelatton. 3 good ranges, normally takes most of the day and always a good drive.
I'll be keen mate, let us know when it gets closer.
Pretty sure there is a white r35 floating round FNQ
That's mine, you won't be seeing it around for a while, I lose my licence on the 26th. Got booked South of Ingham on the way to a track day - I'll be cycling for 6 months. :-)
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
