Great looking car. Would have rathered an r34 gtr, maybe after the lease on this one ends. No doubt it would feel better than a rex, by a lot, I doubt it. Its an 11sec car.
sorry but you cannot compare a wrx (even if it runs 11's) to a gtr, let alone a tommy kaira edition!
the wrx standard is already at its performance limits, by that i mean once u add i bit more power the clutch/gearbox/cv's etc simply cannot hold up!
the gtr on the other hand...well...i had close to 700hp in my r32 & it was strong!
40k technology v's 120-150k technology (chalk & cheese, sorry)
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3499809
  • Replies 51
Posted Images
:yes:
dont worry I luv the gtr much more than wrx's. By the way if you compare an sti or an evo to an r34, they do out perform the gtr in any situation that requires sharp turns and quick stop/start. Though if someone wanted huge power then the gtr is classes ahead.
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3500628
i agree with u - the smaller cars are manouvreable to a certain extend BUT gtr will always be king!
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3500754
whats his number? email it to [email protected]
Call the guy.... you never know mabye hes in a good mood... Good luck .. I had the pleasure of driving this Car On the Wisemens Cruise For a while.. , Out of all the 34's ive driven...I Have never driven such a Smooth 34....
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3501233
Very nice car. I have bought an R34GTT just recently and it is great but I will one day own a GTR but it is on the back burner till i get the money.
Awesome car indeed!!!
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3507215
  • 1 month later...
Thanks mate!!!
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3558283
  • 1 month later...
  • 2 months later...
I Dont blame Ya Sam , This is without a doubt one of the Best R34 GTR's And Also Most Rare In Australia ,
Hey Thanks Moei!!
Where u been, havent seen or heard u in a while.
The same can be said about u R34 GTR also.
Maybe we should try to hook our GTR's up and if we r lucky they might have babies together
That would look HOT!!! lol
https://www.sau.com.au/forums/topic/179286-r34-gtr/page/3/#findComment-3822801
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
