Ive got this clutch hydralic issue that i thought i solved... Basically i can bleed the clutch system, then after a while of driving (say an hour or so) the engagement point gets higher and then with your foot off the peddle there is still pressure in the system and applying on the clutch fork causing the clutch to slip under hard accel
Cracking the bleed nipple on the slave/master (i have ditched the damper in the middle) releases this pressure and all is good for another hour or so...
Now heres the thing, i have rebuilt both the master and the slave, and adjusted the pushrod on the master, but with no solution. The only thing that made a real difference was using an air blower to blast all the lines out and chucking the damper in the bin... then the clutch was fine for a day or so then it was back to acting up.
Slave cyln looks to be perfect, as does the master, so really. im stumped and sick of the damn issue!
You're sure you have the pushrod adjusted correctly at the pedal. Because it sounds like the master is gradually building pressure because it can't release properly. Pretty certain there should be a slight amount of slop in the pushrod when the pedal is fully released.
thats exactally whats happening, master is building pressure, however the pushrod has plenty of slop in it after bleeding.... but it doesnt stay that way!
hair pulling stuff
Compensating port is blocked, fluid heats up and cant return to reservior, therefore it expands and disengages clutch. If you have freeplay at adjustable rod you need to make sure the port isnt blocked.
where about is this port located?
If your looking into the master cylinder, it the small hole closest to the main bore opening. If its out of adjustment the seal will cover the port, stopping the warming fluid from re-entering the reservoir.
so basically i need to strip it down and clean it all out...
Yep, but you also need to make sure you havent fitted a spacer or washer in the wrong spot. In the relaxed position the seal needs to be slightly back from the compensating port.
why not just buy a new master? very cheap and save all this hassle.... rebuilding is fine but for all the hassels youve had id just f**k it off and get a brand spanka. you could possibly have the seals in the wroung way also... primary/ secoendry seals backwards etc.
This is the right answer, you don't need new! Find out, in your assembly of the master, why the seal is covering the hole so the fluid can't return to the reservoir.
I have been through a couple of aftermarket clutch masters and 1 slave cyls.
$75 for the master and $38 for the slave.
The aftermarket master behind a 1+tonne clutch doesn't last too long I average ~40,000km's before they begin to leak. :S
All clutch brake Edwardstown.
I'll go a genuine master and nismo slave (reduced pedal effort) next time roud as I'm sick of removing and installing.
your telling me.. its a fair prick of a job to remove it all, ive done it about 3-4 times now (once cause my clutch peddle box broke)
i'll pull it out and strip the master down again. no idea where this compensating port is but i'll try and figure it out :whistling:
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
