Hey fellas,
Just I'll share this with everyone... of late, I've noticed my engine/oil temperature guage hits the higher end when the engine isn't fully warmed up yet... however, after the engine has in fact warmed up; the engine/oil temperature goes down to mid-range again as normal - can someone please tell me if this is normal or is something wrong... I checked my coolant and it's full no leakage etc.
Cheers,
Hey fellas,
Cheers,
To put simply oil is thicker when its cold, and as it warms up it becomes thinner. Thinner fluid = less resistence = less pressure.
It is completely normal and everycar will do it.
Abit off topic but, why did you check your coolant if you were worried about oil pressure???
Hey fellas, thanks for your replies... glad to hear it's normal.
R34GTFOUR - your question is valid; I checked my coolant thinking that there's something wrong with the engine hence making it overheat and therefore perhaps increasing the pressure of the oil etc - worth a check, I guess.
That's good to know... many thanks everyone.
Regards,
Hey fellas,
Cheers,
If the oil is cold how can it be hot???? Unless when you say temperature gauge, you mean pressure gauge?
Hey mate, I don't know what it's called to be honest - you know, the gauage on the far right corner... has a picture of a oil can or something... always thought it was the engine / oil tempature gauage.
on a related topic...
after the car warms up, is it ok for the pressure to slighty fluctuate up and down onthat guage when on the throttle?
I'm trying a different oil this time and noticed that it rises with the throttle slightly (guessing the oil is thinner?)
The oil level is fine according to the dip stick
Using motul turboight this time, Ddnt use to happen when i used mobile1 which was thinner :S
The pressure should go up and down with revs...
For example...
idle. 1st dash...
3000rpm. half way
5000rpm. 3/4 of the way up...
As the engine is revving the oil pressure is rising.
What I meant was that when your oil is cold, it is thick, it takes a lot more effort to push it through the journals and oilways, and until the oil warms up the pressure reading is higher up to 7kg/cm2 [this also depends on the type of oil and its viscosity rating]. Once the oil warms up, it thins out to its specified viscosity and your oil pressure gauge starts reading 3.5-4.0kg. inversely on a stinking hot day your oil pressure can drop to 3.0-3.5 especially if your oil is old or needs changing.
I guess we've cleared it up pretty good fealls... I just to get worried too - as the pressure gauage used to flucate quite often. Guess it's normal... and I use Mobil1 in my car too.
Also noticed, if you increase the boost - the higher the boost, the more the pressure rises.
Boost has nothing to do with oil pressure. Revs can change pressure. Your oil pump is mechanically driven, it is linked to the motor. So the more the motor revs, the more your oil pump spins, the greater the pressure. This is counterbalanced by the volume your pump can physically supply. It gets to a certain rev limit and no matter how hard it spins or increases revs, it physically cannot pump any more oil, it has reached its maximum flow rate. The maximum flow rate is also affected by the type of oil, the gallery and journal/bearing size, and the scavenge supply [if you flood the head and starve the bottom end supply].
Thanks for the extra information buddy - you've explained this well and in a way that is easy to understand - thank you mate!!
Regards,
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
