hey all
just after a 6 point cage to add some extra rigidity to the 32
just wanted to know how much i should expect to pay for a cusco 6 points (either new or 2nd hand)
can i install it myself? or will i need to drill/weld stuff?
do the cuscos meet vic rules in terms of clearance from the occupants heads?
has anyone got any photos of them installed?
are then annoying in terms of resting ur foot on the door when ur in traffic or does ur hand/watch hit the cage when ur turning or anything?
and has anyone noticed a real difference after they have installed it?
thanks in advance :P
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/
Let alone the fact the cusco one might well be more dangerous than not having one at all :P
Your far better off contacting someone locally.
Going locally will be both cheaper, and built to ADR/CAMS/Vicroads requirements. What more could you want?
Also if you dont know what your doing, then a DIY cage isnt the way as its a "must be done right" scenario as per the first sentence... it might cause more harm than good.
See here:
http://www.skylinesaustralia.com/forums/in...209&hl=roll
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3270573
Ok well i have read the whole thread (even the garbage kim started lol)...
The way i see it, is that i can get the full 6 point cusco cage for $500.. lets say another 100-200 for it professionally installed (i guess its like alarms; the install is more important then the actual components)..
Now that would suit my needs perfectly; Pad it up, its my daily aswell. I only plan in taking the car on the track only to drift it (for now) - as far as i have seen, 90% of these drift days dont require a cage at all, but if you plan on taking passengers, a cage is a must (a majority of us from ns.com have cusco cages and pass winton/calder checks without a problem).
I guess also adds to the whole 'tuffness' of a drift car..
On the other hand, if we can get a group buy of cages that are street legal and are safer/more rigid then the cuscos... i could use it for drift events and if i plan on doing some circuit time (which i may) that requires a cams approved cage, if these comply that would be an advantage.
However, if i decide to go cusco, i know i wont be loosing any money on cages as i dont think they will ever loose value (unless this group buy goes ahead :P )
Ahhhh my dilemma!
Edited by DjeMz
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3270600
If I were you realistically I'd be buying an off the shelf jap cage, just make sure that it is in perfect condition. For your intended use vs cost I'd say this is the best option. However, if you've got the cash for a custom built CAMS approved cage then it's definately the better option, but I'd be planning on keeping the car for a while and doing a fair share of motorsport.
My 2c.
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3271134
yeah, and cutting your carpet, and drilling holes through your cars floorpan, and through your wheel arches, and cutting up some trim. appart from that piece of cake, just don't stuff it up!!! also bear in mind it's not the easiest thing to assemble in the car. it's not like a can of baked beans, you can't just assemble cage, pull the roof off and dump the cage in there.
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3271540
Its not hard to do mine fitted perfectly, i have a 9 point made from 40mm cold drawn seamless tube. which has also been passed by the local ASN of the FIA here in the United Arab Emirates for national events.
And no the rear of the cage doesnt bolt to the stut towers but as Beer baron says its the top of your wheel arches, will post some pics for you.
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3271792
Ahhhh my dilemma!
Indeed there-in lies your dilemma.
I would still be very surprised if the Jap cage meets AUS standards as past ones haven't and im of little confidence this will either.
Also to note, you will more than likely need to re-rego the car as a 2 seater and all that's associated using a 6 point.
So if you install a 6 point cage, dont re-rego it your potentially creating two very large issues with regards to legalities.
Especially living in Melb, its something you'd rather not have to worry about.
When a road legal 4-point cage costs around $700-$800 to be professionally made, and installed to suit the car,
And then you can get removable intrusion bars etc etc
The decision is quite easy as i see it. Get a AUS ADR/CAMS made & approved one.
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3272603
Thing is the cage isnt a matter of urgency, or a necessity. Just a little added safety/value/wank factor on the car. I dont want to re-register the car as a 2 seater also like most of us here, a cage is just another thing to add to the list of our worries in terms of the law...
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3272620
i have the same cusco roll cage as the tacker minus the side bars. Can you confirm if that is the chrome moly one? I have been lead to believe that the blue ones are the chrome moly ones and the black ones are the normal ones. I havent done a comparison in weight with a friends one who has the black one.
and just to reconfirm what beer baron said, its a pain in the ass assembling the cage inside the car!
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3273833
Normal they are i am told, but as we had to order others for a LHD R34 and R33 at the same time. These had to be made to order so we were able to ask for the color. They wanted Blue and i didnt care to much so blue it was.
Few little pics of my mate LHD R34
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3274103
Not at the moment :huh:
But as i said, due to the nature of illegal cages, if they decide to say "Approved cage or none at all", then you've wasted your money.
There was some talk about approved-or-none a while ago, not sure if its going to occur or not though.
Personally i would like it too, a bad cage is a coffin.
So to be honest, if you did roll the car, its likely you'll either maim yourself or die. Fat lot of good your cage did then!
And from the pics above - the blue cusco one will NOT PASS approval here in Aus. No chance with bends on the front pillar like that to go 'around' the dash.
Thats instant fail.
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3278807
yep but thats the price you have to pay to convert a skyline to LHD. You will see in the other pics that its a straight through jobby.
I have no reason to pump these cages, but i have spoken to the JAF who are the ASN of the FIA for japan and these cages are made to appendix J section 253 article 8 regulations. These cage designs have been been submitted JAF who homologated them as the FIA ASN for Japan.
Short extract of the aboved mention regulations;
Any new cage which is homologated by an ASN and is on sale as from the 01.01.2003, must be identified by means of an idenification plate affixed to it by the manufacture, this identification plate must neither be copied or moved ( ie embedded, engraved or self destroying sticker ).
http://www.fia.com/resources/documents/994...ppJ_Art_253.pdf
I have attached a picture of the sticker on the Cusco cage i brought and if anyone can translate it for me and its not what it should be then the person who sold it to me is in for a tough time! as its an eye for an eye in these here parts
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3279213
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
