hey all
just after a 6 point cage to add some extra rigidity to the 32
just wanted to know how much i should expect to pay for a cusco 6 points (either new or 2nd hand)
can i install it myself? or will i need to drill/weld stuff?
do the cuscos meet vic rules in terms of clearance from the occupants heads?
has anyone got any photos of them installed?
are then annoying in terms of resting ur foot on the door when ur in traffic or does ur hand/watch hit the cage when ur turning or anything?
and has anyone noticed a real difference after they have installed it?
thanks in advance :P
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/
Let alone the fact the cusco one might well be more dangerous than not having one at all :P
Your far better off contacting someone locally.
Going locally will be both cheaper, and built to ADR/CAMS/Vicroads requirements. What more could you want?
Also if you dont know what your doing, then a DIY cage isnt the way as its a "must be done right" scenario as per the first sentence... it might cause more harm than good.
See here:
http://www.skylinesaustralia.com/forums/in...209&hl=roll
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3270573
Ok well i have read the whole thread (even the garbage kim started lol)...
The way i see it, is that i can get the full 6 point cusco cage for $500.. lets say another 100-200 for it professionally installed (i guess its like alarms; the install is more important then the actual components)..
Now that would suit my needs perfectly; Pad it up, its my daily aswell. I only plan in taking the car on the track only to drift it (for now) - as far as i have seen, 90% of these drift days dont require a cage at all, but if you plan on taking passengers, a cage is a must (a majority of us from ns.com have cusco cages and pass winton/calder checks without a problem).
I guess also adds to the whole 'tuffness' of a drift car..
On the other hand, if we can get a group buy of cages that are street legal and are safer/more rigid then the cuscos... i could use it for drift events and if i plan on doing some circuit time (which i may) that requires a cams approved cage, if these comply that would be an advantage.
However, if i decide to go cusco, i know i wont be loosing any money on cages as i dont think they will ever loose value (unless this group buy goes ahead :P )
Ahhhh my dilemma!
Edited by DjeMz
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3270600
If I were you realistically I'd be buying an off the shelf jap cage, just make sure that it is in perfect condition. For your intended use vs cost I'd say this is the best option. However, if you've got the cash for a custom built CAMS approved cage then it's definately the better option, but I'd be planning on keeping the car for a while and doing a fair share of motorsport.
My 2c.
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3271134
yeah, and cutting your carpet, and drilling holes through your cars floorpan, and through your wheel arches, and cutting up some trim. appart from that piece of cake, just don't stuff it up!!! also bear in mind it's not the easiest thing to assemble in the car. it's not like a can of baked beans, you can't just assemble cage, pull the roof off and dump the cage in there.
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3271540
Its not hard to do mine fitted perfectly, i have a 9 point made from 40mm cold drawn seamless tube. which has also been passed by the local ASN of the FIA here in the United Arab Emirates for national events.
And no the rear of the cage doesnt bolt to the stut towers but as Beer baron says its the top of your wheel arches, will post some pics for you.
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3271792
Ahhhh my dilemma!
Indeed there-in lies your dilemma.
I would still be very surprised if the Jap cage meets AUS standards as past ones haven't and im of little confidence this will either.
Also to note, you will more than likely need to re-rego the car as a 2 seater and all that's associated using a 6 point.
So if you install a 6 point cage, dont re-rego it your potentially creating two very large issues with regards to legalities.
Especially living in Melb, its something you'd rather not have to worry about.
When a road legal 4-point cage costs around $700-$800 to be professionally made, and installed to suit the car,
And then you can get removable intrusion bars etc etc
The decision is quite easy as i see it. Get a AUS ADR/CAMS made & approved one.
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3272603
Thing is the cage isnt a matter of urgency, or a necessity. Just a little added safety/value/wank factor on the car. I dont want to re-register the car as a 2 seater also like most of us here, a cage is just another thing to add to the list of our worries in terms of the law...
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3272620
i have the same cusco roll cage as the tacker minus the side bars. Can you confirm if that is the chrome moly one? I have been lead to believe that the blue ones are the chrome moly ones and the black ones are the normal ones. I havent done a comparison in weight with a friends one who has the black one.
and just to reconfirm what beer baron said, its a pain in the ass assembling the cage inside the car!
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3273833
Normal they are i am told, but as we had to order others for a LHD R34 and R33 at the same time. These had to be made to order so we were able to ask for the color. They wanted Blue and i didnt care to much so blue it was.
Few little pics of my mate LHD R34
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3274103
Not at the moment :huh:
But as i said, due to the nature of illegal cages, if they decide to say "Approved cage or none at all", then you've wasted your money.
There was some talk about approved-or-none a while ago, not sure if its going to occur or not though.
Personally i would like it too, a bad cage is a coffin.
So to be honest, if you did roll the car, its likely you'll either maim yourself or die. Fat lot of good your cage did then!
And from the pics above - the blue cusco one will NOT PASS approval here in Aus. No chance with bends on the front pillar like that to go 'around' the dash.
Thats instant fail.
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3278807
yep but thats the price you have to pay to convert a skyline to LHD. You will see in the other pics that its a straight through jobby.
I have no reason to pump these cages, but i have spoken to the JAF who are the ASN of the FIA for japan and these cages are made to appendix J section 253 article 8 regulations. These cage designs have been been submitted JAF who homologated them as the FIA ASN for Japan.
Short extract of the aboved mention regulations;
Any new cage which is homologated by an ASN and is on sale as from the 01.01.2003, must be identified by means of an idenification plate affixed to it by the manufacture, this identification plate must neither be copied or moved ( ie embedded, engraved or self destroying sticker ).
http://www.fia.com/resources/documents/994...ppJ_Art_253.pdf
I have attached a picture of the sticker on the Cusco cage i brought and if anyone can translate it for me and its not what it should be then the person who sold it to me is in for a tough time! as its an eye for an eye in these here parts
https://www.sau.com.au/forums/topic/179536-cusco-roll-cage/#findComment-3279213
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
