Item:
auto metre 5" monster tacho (black face)SOLD
oil temp guage 60mm with stand black face (never used just installed on dash)SOLD
water temp guage 60mm with stand black face (never used just installed on dash)SOLD
r33 400r or gtr rear pods whiteSOLD
r33 mspec side skirtsSOLD
s13/14 uras side skirts primed ready yo go
r33 400r front bar in primer( can paint for extra $$$ white or black)
18x8.5 starcorp racing kaotics 80% front 60%rearsSOLD
Website: here
Item Condition: all in good condition some small mark as you would get with second hand parts
Reason for Selling: not needed
Price and Payment Conditions:
auto metre 5" monster tacho (black face) $110 ono
oil temp guage 60mm with stand black face (never used just installed on dash) $50
water temp guage 60mm with stand black face (never used just installed on dash) $50
400r or gtr rear pods white $150
mspec side skirts $150
s13/14 uras side skirts primed ready yo go $200
400r front bar in primer( can paint for extra $$$ white or black) $300+paint
18x8.5 starcorp racing kaotics 80% front 60%rears $1000 ono
Extra Info: buyer pays freight
Pictures: yes pm me if you want some
Contact Details: pm me or txt 0438774173
Edited by johnbarry88
https://www.sau.com.au/forums/topic/179565-parts-clearance/
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
