its got an apexi bov at the moment on the crossover, but by the looks of things the last owner of my car used a different adaptor and drilled holes in it to make it fit... would it be possible to use a thin piece of aluminium (coke can ect.) and make a new gasket?
if it didn't come with the gasket it's meant to, just use gasket goo, CRC Gasket Maker
works fine :P
don't use a coke can, since they are rounded, the gasket won't seal properly
CRC gasket maker? never heard of it... but if it does the trick where abouts can you buy it? autobahn?
You can buy gasket maker at supercheap just make sure its the right one as there are many different types (Some arent oil resitant or fuel resistant bla bla, but you want one for air piping)
or you can get the proper gasket from nissan
or perhaps you can just buy a $2 sheet of gasket paper and use that?? dont know how well that would work tho...
Edited by tek_01
:) This should work fine. Its not liquid or high pressure, just hot'ish air at no more then a few bar.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
