i still think despite the age of your car, if the actuator line is in good condition and is getting an accurate pressure reading then boost pressure will always be constant
zanda no i wouldnt stress. youve always got the boost cut at around 12psi (i think) which would prevent and mecanical damage
hmm.. Suprising because of the mechanical nature of the actuator.
It is my understanding that the mechanical actuator measures the boost level on the compressor side of the turbo and when this level gets to a certain pre-determined point (ie 6 to 7psi for an R33) it then "actuates" or opens the wastegate to keep the boost at that level.
If this is correct, then I fail to see how making the flow in and out (inlet and exhaust) of the turbo will in any way change how this mechanical actuator works. It will still open the wastegate as soon as it sees the set boost level.
The only way I can think that it could possibly produce more boost is if the increase in flow through the turbo is greater than what the wastegate can deal with. Therefore the wastegate is at maximum flow and still more air is flowing due to the increase in size/flow of the inlet and exhaust (predominately the exhaust), producing more boost.
I did not think that the maximum wastegate flow would be so low as to let this happen. I was obviously wrong. Hence I find it suprising.
Always good to find out new stuff. :rolleyes:
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
