  • Replies 47
I did it to my car so that channel 4 on the viper remote closes the sunroof and winds the mirrors in. I too like wanky features! Remote start or turning the ignition on winds them out. Carefull not to let the smoke out of the switch though, it can be hard to get back in!
no not the mirror close, just the "mirror close on door lock" function. Coz if i'm in the car driving and I wanna lock my doors, I dun want the mirrors closing on me...
  • 2 months later...
i gave some thought to this, then after talking to a mate of mine we came to the opinion that it would be best have the mirrors set so that when the ignition is turned on they open, and when turned off they shut.
we will try work out how to set this up so that it has a timed signal to reduce the chance of damage to the mirrors. as im not sure if the motors turn themselfs off after hitting full open or full shut. so if anyone knows about that one feel free to tell.
if we manage to work out how to do this one we are willing to either make them for ppl to buy or simply give instructions on how we did it. probally instructions as we are lazy :cool:
few problems we faced...
when you turn ignitoin off, you have to use the power from the battery source (not accessory, as this goes off when you turn the off)
there's a dude in japan who did it and put up a circuit diagram on his website, I saw it, but then forgot to bookmark it.
you gotta rig the power to the switch that controls in out actually, coz it has a relay that stops power to the motor once the mirror has folded (otherwise you'll put a constant power to the motor and cause the motor to die, also it'll drain your batteries)
so it should be...
car turn on -> send 12v to mirror open SPDT switch
car turn off -> send 12v to mirror close SPDT switch
the switch seems to know when to turn off power to the motor so that's all good.
using capacitors and working out by trial and error will give you the size needed for this. so then you have the nice little timed part. the other thing that has to be done is working out how to have a circuit that sends a power pulse when the key is on and when the key is off. i dont know enuff about circuit shit to really say how to do this. in sep ill sit down with me mate and work all this out. shouldnt be tooo complicated.
with those problems you faced. use the power supply on the back of the key. the wire that is always power. either that or use the one that runs to the stereo. and for sending power when the key is off. using a simple cross over relay.
much more thinking to be done once i have someone to chat with that knows more about that stuff.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
