Hi all,
I need to get a roadworthy for my GTR32. Need one where they aren't picky on things cuz it's quite modified, but it has modification plates. It's just the stuff like it has no ABS, no aircon, etc etc. Basically I need a RWC no matter wot before this saturday!!! Inputs please!
Cheers~
Edited by J-Boy
https://www.sau.com.au/forums/topic/179885-need-rwc-for-modified-gtr/
  [WLDCRD] said:
if he is flying in from victoria, why would he need the rwc? he needs a vic one not a qld one.....unless everything has changed
As above. A QLD rwc isn't worth the paper it's written on in VIC.
He will have to get his own in VIC.
i got my car done at boike autmotive at kuraby, they didn't seem to worry too much about mods but they did look at the safety items, like steering, braking, drive train lights etc. no so worried about exhaust, suspension i.e. coilovers.
If he doesn't need the RWC, but would prefer one, and your going to get a dodgey one.. what is the point in getting one at all LOL
It's not that hard to get one though, just find a dodgey looking place and tell them you want to transfer the car from your dads name to yours asap, works a treat ;)
ACE auto in Murarrie did mine.
Although my car was fairly stock, they did not have anything to say about the following.
18" non standard wheels
Sports steering wheel
HKS blow off valve
Lowered
Eyelids over headlights
Cat back exhaust
They also looked after the car quite well, no grease or shit on the steering wheel or dirt in the carwhich is what you usually get after any mechanic has been in it.
There really are no "relaxed" places anymore, believe me I looked as I was really worried about the above.
They have all been shut down or will only do it for really really close mates.
  J-Boy said:
Thanx guys, didn't need one in the end~ car's sold~
Even so, to clear up something for everyone.
Roadworthy does not depend on modifications done. There are certain guidlines that they must follow. Other than that, as long as the car is essentially safe, it should pass.
If you have a blue plate for your mods, then they should not even need to be checked in a roadworthy
Silly things pass like:
You can have absolutely no baffling left in your rear muffler but if it doesn't exceed noise limits and there are no holes then it passes.
No spare needs to be present.
Only driver's side window has to work
Oil leaks are ok as long as (after cleaned) they do not form one drip within 10 minutes.
Surface rust is ok but can't poke anything through it.
As you can see it's not like you have to have a new car to pass.
