  • Replies 41
LOL!!!
here it is for those who'll miss it..
A HORRIBLE HORRIBLE THING HAPPENED ......
06/11/03 05:10 PM Edit F Reply
I JOINED THESE FORUMS
In reply to:
Don’t be an idiot, no keyboard warriors, keep things on topic.
In reply to:
This is OUR forum, owned by US. We make the rules, if you dont like them go away
hello!, the MCCR forums are a joke. They are so bad. Most of the content is absolute &^%#! and not worth reading. Someone delete my registration as I no longer wish to be part of this crap.
I WISH TO GO AWAY
Post Extras:
oz_utester
member Reged: 02/05/03 Re: A HORRIBLE HORRIBLE THING HAPPENED ...... [re: akeenan]
06/11/03 05:12 PM Edit F Reply
ummm, ok?
then press the white X in the top right of ur screen....
Reged: 05/20/02
Loc: gEt OuT oF mY DaNcInG SpAcE BrO oR I'lL GeT My CoUsInS To BaSh YoU In Da ToIlEtS
06/11/03 05:14 PM Edit F Reply
hi there, do you believe that we are not up to the mental capacity of people more like yourself?
which nobel prizes were you awarded??
Reged: 11/20/02
Loc: Melbourne
Re: A HORRIBLE HORRIBLE THING HAPPENED ...... [re: InsaneAsylum]
06/11/03 05:20 PM Edit F Reply
Please delet this thread... we don't need morons like this clogging up the forums...
Reged: 12/13/02
Loc: Eastern Suburbs
Re: A HORRIBLE HORRIBLE THING HAPPENED ...... [re: Squall77]
06/11/03 05:24 PM Edit F Reply
tru dat
I LOVE that bonehead's comment about being metall capacity... what a phaggot.
tidy work dude :P
https://www.sau.com.au/forums/topic/17993-mccr/#findComment-374934
"Loc: gEt OuT oF mY DaNcInG SpAcE BrO oR I'lL GeT My CoUsInS To BaSh YoU In Da ToIlEtS "
"""""hi there, do you believe that we are not up to the mental capacity of people more like yourself?
which nobel prizes were you awarded??"""""
GREG: i found it amusing reading his location then reading his reply
whats going on? Is Ambz still talking to you guys about porno movies
no ones spoken to me about movies? ......... i wish they had though :(
https://www.sau.com.au/forums/topic/17993-mccr/#findComment-377221
sorry guys, but ill have to correct you on this one..
he is a friend of mine and thats a little personal joke
his basically taking the piss out of some muzzaz that think their top sh|t high up on coke at clubs
his a good guy, knows alot of the shiffy sh|t that goes on behind mccr
https://www.sau.com.au/forums/topic/17993-mccr/#findComment-377279
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
