  • Replies 41
LOL!!!
here it is for those who'll miss it..
A HORRIBLE HORRIBLE THING HAPPENED ......
06/11/03 05:10 PM Edit F Reply
I JOINED THESE FORUMS
In reply to:
Don’t be an idiot, no keyboard warriors, keep things on topic.
In reply to:
This is OUR forum, owned by US. We make the rules, if you dont like them go away
hello!, the MCCR forums are a joke. They are so bad. Most of the content is absolute &^%#! and not worth reading. Someone delete my registration as I no longer wish to be part of this crap.
I WISH TO GO AWAY
Post Extras:
oz_utester
member Reged: 02/05/03 Re: A HORRIBLE HORRIBLE THING HAPPENED ...... [re: akeenan]
06/11/03 05:12 PM Edit F Reply
ummm, ok?
then press the white X in the top right of ur screen....
Reged: 05/20/02
Loc: gEt OuT oF mY DaNcInG SpAcE BrO oR I'lL GeT My CoUsInS To BaSh YoU In Da ToIlEtS
06/11/03 05:14 PM Edit F Reply
hi there, do you believe that we are not up to the mental capacity of people more like yourself?
which nobel prizes were you awarded??
Reged: 11/20/02
Loc: Melbourne
Re: A HORRIBLE HORRIBLE THING HAPPENED ...... [re: InsaneAsylum]
06/11/03 05:20 PM Edit F Reply
Please delet this thread... we don't need morons like this clogging up the forums...
Reged: 12/13/02
Loc: Eastern Suburbs
Re: A HORRIBLE HORRIBLE THING HAPPENED ...... [re: Squall77]
06/11/03 05:24 PM Edit F Reply
tru dat
I LOVE that bonehead's comment about being metall capacity... what a phaggot.
tidy work dude :P
https://www.sau.com.au/forums/topic/17993-mccr/#findComment-374934
"Loc: gEt OuT oF mY DaNcInG SpAcE BrO oR I'lL GeT My CoUsInS To BaSh YoU In Da ToIlEtS "
"""""hi there, do you believe that we are not up to the mental capacity of people more like yourself?
which nobel prizes were you awarded??"""""
GREG: i found it amusing reading his location then reading his reply
whats going on? Is Ambz still talking to you guys about porno movies
no ones spoken to me about movies? ......... i wish they had though :(
https://www.sau.com.au/forums/topic/17993-mccr/#findComment-377221
sorry guys, but ill have to correct you on this one..
he is a friend of mine and thats a little personal joke
his basically taking the piss out of some muzzaz that think their top sh|t high up on coke at clubs
his a good guy, knows alot of the shiffy sh|t that goes on behind mccr
https://www.sau.com.au/forums/topic/17993-mccr/#findComment-377279
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
