  • Replies 287
I have to say a great big thanks to Justin first of all for giving up his whole friday night... Great photo's!
Also to LadyBytes (Michelle) for organising the night, Mark (LadyBytes man) for taking some great shots aswell and everyone who turned up... :P
Everyone was well behaved on the roads (except for a certain Supra) and therefore we all had a good night!
I would like to express my thanks for Justin's efforts by starting up a VOLUNTARY donation fund for his time and dedication, he doesnt even own a Skyline and he spent 6 hours from 8pm until 2 am snapping away for our benifit...
I am personaly going to donate $10 and I think that if we get the ball rolling (and $5 - $10 each isnt much) Justin will be overwhelmed by our thanks.
C'mon SAU ACT people, if you were there on Friday night you know that it was worth it!! ;)
P.S. any idea's on how to pool the money together would be appreciated.
;) I'll put in - You should drive around and visit us all with a collection tin and pink frangipanis on your car *nod nod*
Also to LadyBytes (Michelle) for organising the night, Mark (LadyBytes man) for taking some great shots aswell and everyone who turned up... :)
THANKYOU! :);):P :P
I did use to own a skyline....
What supra? It wasn't my mate in the black JZA80 I hope.....
Anyways, we'll have to organise another night for the rolling shots threw the parksway tunnel, and also, anybody who wants pic's at the museum please PM me and we'll sort something out.
I'll get to burning the CD's over the next few days.
Thanks again.
HEHE I know... thats why its so much fun putting frangipanis on your car... looks so YOU!! ;)
You have started a war that you cant win Michelle hehehehehe :P
I know how you love your Holden's. :laughing-smiley-014:
Edited by Bullet32
I dropped my clutch, still getting used to the brass button, and I had a little chirp going back onto Parkes Way. I felt pretty stupid, but this clutch is hard to get used to. Sorry if I got anyone in trouble.
Daaaaaaaaamn... I need to get my frount mount in and get you to do some photos, or atleast come along to the next shoot, those photos are awesome! And rolling shots through the parkway tunnel would be wicked
haha cheers, looks great, wish it wasnt a white car though :P
dam, should of hopped down from the dumpster for the group shot, lazy bastard
Edited by Baconer
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
