haha cheers, looks great, wish it wasnt a white car though :P
wish id hopped down from the dumpster for the group shot, alzy bastard
*sniff sniff* I think I can still smell chicken :)
  • Replies 287
Ive just been playing around with the idea of SAU ACT official club and I came up with a simple banner design... (not that simple really)...
I just whipped this up pretty quick, if I had more time I could do heaps better, but its just an example.
What does everyone think?
Edited by Bullet32
Well naturally I like it A LOT cos you used a beautiful @rse shot of my car... but that aside, it looks awesome.
Here's another one, I like this one cos theres all models in it (except R34 :P)
Like I said, these are just examples, with more time they will be better.
Edited by Bullet32
I agree with the second one and by the way 'donation' - no problem
Regarding the shots where's the best place to get them printed and framed
i am more than satisfied with the results.
