Hi,
I've got my Profec B spec 2 for sale, had it in the car for about 2 months, no longer needed as I've got an HKS actuator doing a fine job on its own :thumbsup:
It's the black one, comes with the box and all the bits ready to fit, does an awesome job and is easy to use. Literally perfect condition.
SOLD
Got a used HKS fuel cut defender...I never got around to putting it in, don't actually need it anymore.
SOLD
https://www.sau.com.au/forums/topic/180173-greddy-profec-b-spec-2-hks-fcd/
