After looking at the ignition dwell duty table values. I googled for the conversion from dec to milliseconds, and discovered a few differing methods that yeld some very different results.
firstly there are 32 (RPM) points in the table, some believe that these are in 400 rpm blocks thus going from 400-12800 rpm (seems unlikely). 200 rpm intervals seem more likely eg. 200-6400 rpm.
next the dec values I imagine have a conversion value to convert them to a percentage, two variations on this one.
1. divide by 10
2. multiply by .33
I favor the option 1, but could be wrong.
Now to convert dwell duty percentage into milliseconds.
I used this method (1/(RPM) X 6000) X Duty % (in decimal).
This gives me a peak of around 4 ms at 200 rpm and an average value of around 2 ms for the rest of the table.
Am I on the right track with this one?
https://www.sau.com.au/forums/topic/180258-z32-igniton-dwell-duty/
Looking at the Z32 ECU I have tried to come up with a conversion table to ms and came up with zip! I have tried longer dwell on standard coils and had better burn and more torque but prone to detonation and shorter dwell and less prone to detonation but guaranteed way to fry coils.
From what I have gathered there is 2 increments per RPM scale and they seem to differ. by best guess would be use the RPM scale as a guide and devide each increment by 2 for your 32 points.
As for dwell values there was a table somewhere I will have a look and see if i can dig it up. but the results were a bit shady. there was actually a brand of coild called FET. and they gave specifications that indicate they were designed for a min of 2ms and no less.
sorry can't be much help :)
there are numbers of GTR's in japan making 800ps with standard coils so they know something we dont...
high on painkillers right now sorry if my explination is not the best...
Here is a table of values using data at 7B60 tp 7B7F.
200 Rpm - 4.50 ms
400 Rpm - 2.25 ms
600 Rpm - 2.20 ms
800 Rpm - 2.40 ms
1000 Rpm - 2.52 ms
1200 Rpm - 2.60 ms
1400 Rpm - 2.57 ms
1600 Rpm - 2.66 ms
1800 Rpm - 2.70 ms
2000 Rpm - 2.82 ms
2200 Rpm - 2.84 ms
2400 Rpm - 2.90 ms
2600 Rpm - 2.91 ms
2800 Rpm - 2.98 ms
3000 Rpm - 3.02 ms
3200 Rpm - 3.04 ms
3400 Rpm - 3.07 ms
3600 Rpm - 2.98 ms
3800 Rpm - 2.91 ms
4000 Rpm - 2.82 ms
4200 Rpm - 2.83 ms
4400 Rpm - 2.84 ms
4600 Rpm - 2.84 ms
4800 Rpm - 2.85 ms
5000 Rpm - 2.80 ms
5200 Rpm - 2.69 ms
5400 Rpm - 2.59 ms
5600 Rpm - 2.50 ms
5800 Rpm - 2.41 ms
6000 Rpm - 2.33 ms
6200 Rpm - 2.25 ms
6400 Rpm - 2.18 ms
Seems to fit in with CEF11E info on the coils.
Maybe someone has measured dwell in ms at any of these points and can confirm if this correct.
I made it.
Took the values in the igniton dwell duty table, Converted them into dec.
Divided them by 10 (Conversion in to Dwell Duty %).
Then applied this formula ((1/RPM) x 60000) x Dwell Duty % (as decimal).
I scaled each of the addresses as 200 RPM Intervals.
eg. 32 addresses = 200 - 6400 rpm.
EXAMPLE:
Value at 7B60 is 0F or 15 dec.
15/10 = 1.5
((1/200) x 60000) x 0.015
(300) x 0.015 = 4.5 ms.
This is how I got those values in the table, still not sure if it is 100% accurate.
It would be good if someone has measured the dwell time at a few of these points to prove or disprove this method.
The other option of scaling the table in 400 rpm (400-12800 rpm) intervals is still possible, with smaller values.
Somewhere around 1 millisecond lower at a guess.
Just thought i'd add that the reason behind all this is that I plan to use LS1 coils in the future if my Ser 2 coils give out.
I'll probably increase the dwell for these as i've heard that they are a little slow and need around 3-4.5 ms of dwell.
its an iduuctive coil. around 2mh. the norm is the higher the inductance the longer the dwell needed. the longer the better. but the longer it is the more heat is generated in the coil and driver.
generally to get a very good spark around 3-4ms is nominal. 2ms would be at tyhe very bottom of the scale without having to close down the gap.
ive been playing around with differant coil for my cdi set up. and found tha a mitsubishi gto coil pack is no good. cos its got an inductance of 6mh. where as my mazda coil are only 3mh. so they need half the charging time.
you need to workout how many ms are available at full rpm.
I believe that those numbers are too high, when you put those sort of dwell numbers into an aftermarket computer the stock coils burn out, i was under the impression that the stock system runs about 1.7ms
Edited by Adriano
Okay,
TO4GTR - Maximum dwell duty % would be 25.5 %, That would mean that @ 6400 rpm max coil charge time would be 2.38 ms.
Adriano - The RPM Scale that I am using could be either 200 or 400 rpm i'm not sure which. If I was to use the 400 rpm scale it would give me values about 1 ms lower than those in the table.
NOTE:
Motec recommend a constant 3ms charge time for LS1 coils I hear, when I make the change i'll double check this.
  • 1 month later...
I am fairly new to all of this, but I do have the attached document that seems to show the increments are in 400rpm and the conversion is 1/3% to ms. Using the equation from earlier in the thread for a stock RB20DET ROM I am getting between 1.4 - 2.3 ms of dwell.
090318_1_.pdf
This is a dwell table from my wifes 93 z32, vg30dett.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
