hey guys,
i have had my gtr sitting for about a year and went to start her yesterday and she doesnt want to kick over??
anyways i checked everything out and 4 out of 6 of the coil packs were sitting in water (down where the plug is), looks like it has been sitting there a while too. so i got all the cr@p out and fixed that up.
also, the fuel has turned to varnish.. i took the filter out on the pump side to find out if i have any pressure. i turned the key and some fuel came out but not that much and then after about 4 seconds it started dripping like it was clogged? i turned it off and then back on and there was nothing still? waited 30seconds and redid it and pressure and then it died again!
im wondering if the pump is dead, causing it not to crank over? or could it be the spark plugs.. new iridums.
dan
Edited by Rude Carz
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/
  • Replies 46
ok, i just cleaned the lines that go prety much up to the reg..
i have checked the packs for spark.. all clear..
i have checked the packs with plugs on the end.. all clear..
so, its got fresh 98octane in it.. clean lines, tank, and pump.
what the hell else is there?
help!
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3280815
ok, injectors were fully flow tested and cleaned today, they were fully blocked..
still.. she is not cranking over, put some aerostart in the vac lines and she wanted to start but couldnt..
i am begining to think its the CAS. it might be stuffed or seomthing??? i dont believe i am getting any power to the injectors.
either that or the ECU is stuffed!
i need some advice here!!!!!!!!!
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3285105
It may have fouled plugs, pull one out and see if there wet with fuel.
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3285188
so i take it you're sure the injectors are firing properly now? maybe pull them out and take the cas off and give it a spin too verify that they are properly working..
after having the coil packs sitting in water for so long perhaps the springs that sit inbetween the bottom of the coil pack and the spark plug have become corroded, try checking them out :D
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3285262
U need to remove an injector plug from the top of one of the injectors and insert a noid light in the plug.
If u are getting a signal from the ecu the light will flash,meaning if u have spark like u say its not likely
the ecu. Next step would be to check compression.
U may be able to purchase a noid light from repco etc or borrow one from your mechanic.
Good luck
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3285319
ok, just ran ecu diagnostic and got a 55 back.. so all is good there.. i dont understand???
i shot some aerostart in the vac line and it wants to crank over and splutters a bit and waht not..
i have pulled out the CAS and it is fine although i havent put the ign on a turned the sensor to see if there is injector pulse..
HELP
does anyone live in brisbane and would be able to help me out?? PLEASE!
dan
Edited by Rude Carz
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3308825
Mate trhis may sound silly but have you changed the fuel filter since you said it was blocked? If you really wana know, pull out your injectors, crank the car & see if they spray fuel. Maybe even one will do... Do the same with your plugs if you havent already
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3309111
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
