Coming from a V8 family, and also owning a HQ Panel Van running a 308, all of our cars have two pipes out the back.
I'm looking at this as more a visual thing, but what would be the performance Pros and Cons of a Dual Exhaust on a Skyline. I'd be looking at going from the extractors back, putting three cylinders down one side and three down the other.
Thanks for your help and opinions...
https://www.sau.com.au/forums/topic/180381-dual-exhaust/
you'll just be adding more weight for no reason mate.
i think the v8's join in the middle (manifold on each side of the V setup) then split in the end (someone correct me if im wrong).
but our straight 6's have the manifold on 1 side so you wont really gain anything (but weight) from doing this.
plus the other side of the rear where you'd be running the extra muffler doesnt have that recess to fit it, so it'll be hanging pretty low.
https://www.sau.com.au/forums/topic/180381-dual-exhaust/#findComment-3281225
Most V8's do have a full Twin Exhaust, but on a skyline I think it would be a waste of time and weight.
If you want it just for the looks just split into a T-piece at the back and have 2 pipes just at the back.
This is a Late Model Monaro...Full Twin.
They also use this method where they have joiners in 1 or more places, something to do with equalisation of airflow or something, not entirly sure. But still a full twin non the less
Edited by Turbo Dave
https://www.sau.com.au/forums/topic/180381-dual-exhaust/#findComment-3281236
I hadn't really thought about the weight issue... ...Thanks for bringing that up...
My HQ doesn't join. Keeps four on one side and four on the other. The Comedydor does the same. The Ford has a pipe joining the two half way down, but we don't know if it lets any flow between the two sides...
https://www.sau.com.au/forums/topic/180381-dual-exhaust/#findComment-3281448
Thanks for sugesting the T-piece.
The Ford has a join piece, but we don't know if it lets air flow between the two. It might, but it doesn't look like it.
Whould you happen to know what 300ZXs run? It it a T-piece or Dual Exhaust?
Thanks...
https://www.sau.com.au/forums/topic/180381-dual-exhaust/#findComment-3281453
lol @ thread
300zxs are V6 so hence twin turbo or not they run seperate exhausts... to the back
your r33gtst dosent have extractors nor could run seperate exhaust from the manifold back unless you twin turboed it...
have you looked in your engine bay? it goes Exhaust MANIFOLD through the TURBO then DUMP PIPE then FRONT PIPE then CAT Then Rest of Exhaust....
if you were to have a dual one it would only be for looks and a bit difficult on a skyline as the petrol tank is kind of in the way...
if you really want dual go something like this
looks much tougher.. imo
https://www.sau.com.au/forums/topic/180381-dual-exhaust/#findComment-3281494
I could be wrong here but I believe there is one big reason to go 2 exhausts at the back.
With two pipes out the back (split after the cat), you get the same amount of airflow but with smaller pipes therefore less noise.
It makes sense for those who want power without exhaust drone.
I'm not 100% sure how much quieter 2 pipes are than 1 though...
https://www.sau.com.au/forums/topic/180381-dual-exhaust/#findComment-3281878
Twins are quieter; flow extremely well vs the noise they produce and often than not drove MUCH less if nothing at all.
Twins FTW if you can fork out for a twin 2.25-2.5" system.
Its the same on the old V8's; twins are quieter than the big singles. Owning v8's in the past its always been the case.
The big single on the V8's personally I think sound better.
https://www.sau.com.au/forums/topic/180381-dual-exhaust/#findComment-3281920
I just recently put a full dual exhaust system on my car. Its the full race spec Kakimoto racing Full Mega N1. 75mm each pipe from each turbo all the way back. No cat factor.
I can certainly say there's no drone anymore just pure "race crackle" if that makes sense with each gear change esp after 3000 rpm. I havent put it on a dyno, but what I have noticed is the turbo response seems to be much more punchier and revs much faster. Also love the Kakimoto quality stainless steel all the way through, that much nickle content a magnet can't even stick to the pipes.
No trouble from fun cops as of yet, though I drive pretty sedate unless a wrxy boy or a commonwhore comes along.
These are Mine, which are now discontinued http://www.nengun.com/kakimoto-racing/full-mega-n1-full-dual
https://www.sau.com.au/forums/topic/180381-dual-exhaust/#findComment-3281950
lol @ thread
Never really had anything to do with 300ZXs, so never really had any idea whats in them.
All cars have "extractors". It all depends on whether you call them "headers", "extractors" or "eshaust manifolds". Putting in the second turbo has crossed my mind. But think I'm going up in costs and power that I'm not really after. I still have to drive it every day for work.
https://www.sau.com.au/forums/topic/180381-dual-exhaust/#findComment-3282624
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
