looking to buy some new rims and found that my r33 s2 NON TURBO gts-4 uses 4 stud rims and turbo models use 5 stud..is this correct?
well ive been searching around and not easy to find 4 stud rims that use 235/45/17 tyres and abit frustrated. there r 17'' 4 stud rims but uses 205/40/17 from 4cly cars etc and seem abit small for me and less grip? so wondering does any1 around here have a set of 17'' 4stud rims that may fit 235/40/17 on onto my r33 :( or close 2 it that will sell?
thanks for any help
https://www.sau.com.au/forums/topic/180386-looking-for-4-stud-rims/
I think you'll have a better chance of finding nice/good 4 stud rims on nissansilvia.com because they've got more cars which use 4 studs (S13's, 180sx etc).
And it's pretty hard to find nice 4 stud wheels. Good luck with your search.
the wheel is 17 inches in diametre, is 9 inches wide, and has an offset of +32
if you want the definition of offset, use google... I know what it is, but cant really explain it
Edited by retox
Oh one more thing. Do your research with offsets before purchasing wheels. Usually the lower the offset, the more the wheels would stick out of your guards. I think just learn abit more about wheels in general and you'll understand what offsets you want/need.
thanks, atm im using 235/45/17 tyres and need advice on what size rim is suitable. 17x8? 17x9?
also i am unsure of what my stud pattern is. Since being a nonturbo s2r33 its a 4stud and i THINK i read somewhere its 4x114.3? not sure
some1 correct me lol
Edited by OoskylineoO
Yes, you are correct! Skyline 'PCD' or stud pattern is 4x114.3 or 5x114.3, I'm not sure of the offset values for the 32's or 33's but I assume they would be simlar to the 31, however you'll have to allow for brake caliper clearance and clearance of the strut. They are the main issues when trying to find 4x114.3 rims.
Like the others have said, it is hard to find that style rims. Workout what offset is ideal (for the R31 its +10 to +30 7 to 9" rims)
Depending on what sizes you want, you'll have to work it out. Anything about +35 is going to give you issues clearing the struts.
The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tyre assembly. This in effect brings the tyre further into the tyre well.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset. a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle.
Like others have said nissansilvia & other silvia or Toyota sites are good, as they share the same stud patterns. if you have a good amount of money to spend you could always look at importing something from japan, as there are some amazing rims at decent prices.
hmmm 4 stud rims arn't that hard to find...i mean you can get 4 stud Nismo LM4's i think thats waht they're called and works meisters...in 17 inches or so the question is are u wiling to pay the price :nyaanyaa: but yeah go on nissan silvia there is some one there selling rims especially 4 studd ones for cheap well reasonable prices :thumbsup: hope that helps
Cheers
Chi
hmmm 4 stud rims arn't that hard to find...i mean you can get 4 stud Nismo LM4's i think thats waht they're called and works meisters...in 17 inches or so the question is are u wiling to pay the price :D but yeah go on nissan silvia there is some one there selling rims especially 4 studd ones for cheap well reasonable prices ;) hope that helps
Cheers
Chi
Yeah, it's not all that difficult to find 4 stud rims. It's just hard finding ones with good offsets and a good/affordable price.
Another thing to consider is possibly converting ur 4 stud to 5 stud. Its a worthwhile investment and will open up a whole lot of possibilities in terms of wheel choices. 4 stud wheels are out there but to find a set with the right offsets and at an affordable price is gonna be pretty hard.
Yeah it cost about $1000 for the parts and I think it was installation as well? for the 5stud and bigger brakes. I think it'll be a good upgrade if you can't find any good rims. Not only do you get 5 studs, but you also get bigger/better brakes.
o oright ill think about that but atm i got another question lol, so 235/45 tyres would fit on both 17x8 and 17x9 rims, since i have a gts-4, if i had 17x8 rims on the front and 17x9 BUT i put 235/45 tyres on ALL the rims would that still affect my ATTESSA????
would 17x7 rims rim seem abit umm..thin?? on an r33 lol
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
