Hi.
Have a question about me RB25DET s1 engine that im building.
My tourque wrench is one from work, our test department uses it. Its calibrated 2 times a year, and uses a dial gauge built in it. Goes from 0 - 80Nm.
Just tourqed down the main cradle, but now my crank sort of "binds".
When the crank just has been turned around, it will spin free, and only require ~2 N to be turned. (You cant really measure it as it really doesnt move on the dial.) Easy to turn by hand.
When the crank hasnt been turned for a minutte or so it "binds". Will need around ~5 N to get it to spin free again. (On the dial gauge you can only see it move, and then drops back to nothing as the crank begins to turn / frees it self from the "bind")
Is this just oil friction I have to overcome just when turned? or?? Could this be a problem?
Best Regards
Ronni
https://www.sau.com.au/forums/topic/180559-is-this-okay/
The applied force just need to be a little higher to get it to turn over when it has been standing still for a little minutte or so.
After it has begun to turn the applied force to turn it is close to nothing. It turn freely the hole way round. There are no spots were it feels more or less freely to turn.
https://www.sau.com.au/forums/topic/180559-is-this-okay/#findComment-3283101
Have measured both crank and cradle, ordered correct bearings, got the ordered bearings. Mounted with clean surfaces (back side of bearing) and used plenty of motor oil to lubricate.
When it is turning it feels free and top nice. My only concern is what it is that is "holding" it when it hasnt rotated for a minutte or so. What i need to overcome for it to turn.. Could it just be oil friction? Because when using the tourque dial gauge the applied force to get it turning (when i have to overcome what is holding it) is only just the needle moving, only just moving, not even up on the dial...
But when it has just been turned, and then turned again there is nothing holding it. The needle doesnt move to turn it.
Tomorrow i will try with a different tourqe dial gauge. goes from 0 - 8N. Should be apple to see more accuratly.
https://www.sau.com.au/forums/topic/180559-is-this-okay/#findComment-3283150
On older engines, it was perfectly fine to use oil, i cannot comment on whether grease would have been better or worse. But I thought your not ment to use grease on ur main cap bearings.
What I can say, (which sounds like your describing), is that when the crank is stopped, its harder to get moving, then once its free its fine. then when u stop, it sort of sticks.
On the last rebuild on my v8. The crank did the same thing. and it was perfectly fine. If your really worried about it, borrow another torque wrench, and retorque it. and see if its the same.
since their is no oil pressure, the bearing oil hole and groove, can only pickup oil from spinning. when you sit still, the oil is pushed back off the bearing into the groove, you have to then spin it to pick up the oil into the hole and groove again.
Thing is, you must still be able to move it buy hand, at the correct torque. if its harder than that. its possibly too tight.
but i would rather a professional post here. as Im a novice. good luck.
Edited by silverbulletR33
https://www.sau.com.au/forums/topic/180559-is-this-okay/#findComment-3283710
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
