i've thought about fitting some more and decided that i want to dyno my car before and after so i might get ice or BMT or somewhere like that to fit them.
ps i paid for the extractors today :P rockie said they should be despatched early next week so you should receive them about 2 weeks from now. thanks everyone for your quick payment.
cheers
greg
does neone have an approxmimate price for fitting of these?? also am getting a apexi afc fairly soon along with a high flow airfilter and will have to get the car dyno'd is dyno tuning expensive??
Sorry dude, but i live in brisbane, melbournes a bit of a hike, hehe, nah i already have a place lined up to put mine on, i was just after a ball park figure for duno tuning thats all.
Cheers
John
Hey guys,
Just a bit of an update: the exchange rate was slightly better than expected (budgeted for 1.1000 and received 1.1135) but the transfer fee was slightly more (budgeted for $20 and payed $28). They pretty much even each other out, but I ended up making a huge profit of $8 :D
I had to pay for an extra set myself to make up the numbers, so if anyone (prefereably in melb) wants to buy it then pm me.
I think I've let most of you know already but I'm going on holidays for two weeks (leaving this saturday) so after then the best way if you need to contact me is on my mobile.
Regards
Greg
Sorry Clint I have to be fair here, neoGT-25 asked me first about 1 hour ago so I'll give him first go at them. If he deides against it or takes forever to get the money, then you'll be next in line. Alternatively I could auction them off? :D j/k
It cost me about $100 to get my Cobe extractors fitted, just to give you guys an idea... It took a little longer than I was expecting because they had to grind a side off all 12 of the washers, to miss the welds on the extractors.
yep its true, i'm currently in the cook islands :)
At the other end couldn't you just get them to weld a flange to it so it does bolt on to the cat? this would make it easier if you wanted to change your cat in the future. it sounds a bit dodgy about grinding them down, i thought they were meant to be a straight bolt on.
i had a look at the standard extractors today and they suck! piping is really small and bends obviously aren't mandrel done. also you guys should tighten your throttle cables. i took a fair bit of slack out of mine and it's much more responsive now :)
cheers
greg
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
    • Out of curiosity, how do officials determine what the OEM ride height and suspension specs are? Do they have a book of truth? I'd think that would be quite obscure knowledge for random JDM cars.
    • This is the check list they sign off on. This implies that adjustable coilovers of the type we're referring to are not a "Variable Ride Height" system. This very much is in the ethos of "I can change the height while moving/while parked without pulling wheels off the car and mechanically doing so"
    • Just an update  ... Put the cat back on no issues with the car running wise ... maybe alittle longer to spoil up the turbo. Still running rich but waiting for my tuner to come back into town to retify the situation. WOT runs fine with the cat.
