could you have the CO2 purge like the NOS like out the sides?
yeah, its very easy, i know the company that makes the c02 cooler sprayer also makes the purge system i try and find the link for you
edit here you go
http://www.designengineering.com/products.asp?m=sc&cid=1
and an australia supplier http://racespec.com.au/index.php?cPath=30_63
https://www.sau.com.au/forums/topic/181338-purge/page/2/#findComment-3297238
Use a fire extinguisher man... easy done....
Haha a fire extinguisher would be good but you can get into trouble with them if someone complains. . . . My mates "borrowed" some extinguishers form a petrol station and went round spraying people on the streets and even went into a cafe' and squirted them, and at the end of it all they ended up getting charged with 23 counts of assault.
Haha still funny though :laughing-smiley-014:
https://www.sau.com.au/forums/topic/181338-purge/page/2/#findComment-3299282
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
