just looking to see if there is any other ballarat located members on sau... spotted a nice white line the other day and would love to have a chat and peek at the car, even have all the local skyliner's meet up to look over each others ride and talk some sh!t together
https://www.sau.com.au/forums/topic/181444-ballarat-skyline-owners-speak-up/
ahaha i live near Ballarat and when i was looking for a r33 sedan i noticed quite a few for sale in Ballarat. There was two almost identical gunmetal ones, both auto, both around the same kms, both stock for sale there!! only difference was a spoiler.
Do you guys ever go cruising Grampians way? As in on the Halls Gap pass etc? I used to love cruising up there but am not so confident to go there in my sedan now that it has a 2 way...
happenin cookie!!! and yes i know your here.... yeah it is quite a surprise at how many owners actually dont get on SAU, but it would be nice if i could get a few skylines together locally for a nice cruz! as our local cruz club has since shut done due to lack off interest, cookie if you ahve any info for me shoot us a pm on here
  • 2 months later...
  • 1 month later...
Yep thats me ..
You from ballarat 2 ?
If you look at my avata you can see that it used to have a 400R front bumper on it, but i killed it on my driveway so i have the stock one on now ..
Edited by Mick
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
