So after unpacking the rest of my boxes since the move (only took me 12months :rolleyes: ) i came across some stuff i wont be using.
Central 20 ECU with Dr Drift remap/s and Central 20 chip.
Dr Drift remap 1 = Speed/boost cut, bigger turbo, dump, FMIC, fuel pump.
Dr Drift remap 2 = Speed/boost cut, bigger turbo, dump, FMIC, fuel pump, Z32 & injectors.
Central 20 remap = same as remap 1 but also additional injectors.
$350 for the lot
APEXI AFC
Came in car when imported, never used.
$80 SOLD
GReddy Rebic - injector controller
Was in good working order when car was imported, removed while tuning.
$100
OMORI mechanical gauges
White faced all in car when imported.
Oil pressure
Oil Temp
Exhaust Temp
Water Temp SOLD PENDING PAYMENT
as far as i can tell all fittings are still there but i never had them hooked up so i cant be 100% sure.
$150 each or will do package deal.
GReddy boost gauge - came in car in good condition with gauge holder
$140
R32 GTR injectors x6
never used, when purchased they were cleaned and tested and in good working order.
$350ono
Z32 - 2nd hand but in good working order (NO PLUG)
$200 SOLD
Have more items will list later on and will add pics
All prices are negotiable and located in Tasmania but willing to send at buyers expense.
Please reply, PM or bj_glover at hotmail.com
What sort of power were u making on the No.1 Dr Drift remap?
200rwks which was the limit of the stock AFM and injectors, can scan & post graph if you like :laugh:
IF THE INJECTOR CONTROLLER INCLUDES EXTRA INJECTOR DRIVERS I'LL TAKE IT.
even if it doesnt im still keen for it!
Includes everything that was in the car, will post pics up of whats there :)
Cheers Ben
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
