at a gues i'd say the side that is dark or dimly lit, is because the leds on that side are the wrong way around.. the dim light will be the remainder light from the other side.. just try truning the LED around on the side that's dark.. if not check the LED is making contact
ok i just remembered something. yea i dumbly put the LED in the wrong way with 2 of them so got that fixed...AND i just remembered ...ive got blue light emitted but just remembered that i had ordered the WHITE led's :S ....can we do something about this? ive still got the packaging and have had less than an hr's use...
Blue means you have blue film behind the dials it's put in some of the dashes to reduce the amount of yellow light from the factory globes, if you look at the odometer you'll notice it's pure white (as there is no film over it) but the dials will be blueish, it's covered a fair few times in the LED sale thread, some cars have the film some don't, all R34's have it.
All our globes are colour coded, white base, white bulb, blue base, blue bulb.
This is a late model 180SX with it, note areas of pure white which are circled, this is the true colour of the globes showing through in areas without the blue plastic film
This is what blue looks like installed, it really is very blue
i have your blue leds installed in my r34 dash and aircon and the lighting isn't really even .. you can see how its darker and weaker in some spots. My throughts are this is because they're directional leds.
wouldn't it give better, more even light coverage if it was a single led (instead of 4x3v small ones) and non-directional ??
A single LED gives horrific results, they're even worse for lighting as they tend to have a more directional design than the rectangle LEDs and less output. I've even tried some newer cree diodes and can't get the coverage of this tri-led design. The main problem with the R34 dash is you're trying to illuminate a large dash with 4 small bulbs. The R33's have 5 large T10's to light the dash up so look much better.
Even with the stock bulbs I can see light and dark patches in the R34 dash, it's just poorly designed. When you put a brighter bulb in it's more noticeable.
  • 2 months later...
  • 5 months later...
Just bought the white ones yesterday prob will install them next weekend i hope it's not too hard to do this.
Mate its a piece of piss! Print this guide out and follow it, its great - http://www.skylinesaustralia.com/forums/Re...lu-t228667.html Just remember to check the globes are in the the right direction and working before putting everything back together. I put 1 globe in at a time and the tested it, as you work across the cluster you'll see it light up with each globe.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
