  • Replies 160
Posted Images
Sorry for the noob question - but can anyone confirm if there will be a printout rather than just on screen display and explain the basic run through of the set up and whats involved? Have attended dyno days before as a spectator but never payed too much attention to the precautions, whats required of the car and what not....
Cheers
You rock up, make sure you're paid up, get a place on the list, make sure you line up ur car when it's meant to be dyno'ed, stand back and watch them rev. Get your print out (I've never seen a dyno day without print-outs, please confirm John), you look at your printout and go 'hey! xxx kw, not bad!' and then 1 week later you wonder what you can do for more power :cheers:
Cheers
Hey Towlie,
Yes you will get a printout.
We do a quick check to make sure the car doesnt run lean then we do 2 power runs and give you a print of the power.
The print will display power, you AFR and Boost.
If you would like to know anything else just ask.
Regrads,
Cristian
Cristian,
RE the printouts - I've seen some with kW/AFR/Nm plotted against RPM and speed. Engine speed doesn't really mean too much to me (mechanical neophyte), whereas RPM does. And the last dyno I had was kW + AFR vs RPM. Ideally I'd like kW + Nm vs RPM. Car's stockish, so don't care about boost, feels like it's holding fine to redline. Is that a viable combo? :D
Cheers,
Ben
Edited by sl33py
Cristian,
Cheers,
Ben
Ben,
That can be done but remind me as my memory will fail me by then
Regards,
Cristian
For me personally i think KW + AFR vs Boost is great for anyone wanting to see how safe there mixtures are and if it's over boosting. In saying that it is also cool to know how much torque your car is making and at what RPM your car is no longer making peak power, speed means nothing as far as i am concerned.
Cristian: Cool, I'll remind you.
I agree leech, but the only mod I've got is full exhaust/cat and it's been running healthy for the past 2 years (yes!: *yawn*), so chances of overboosting are pretty much zip :worship: More interested in torque this time. When I do my first proper mod (ECU in the next 6 months), then I'll wanna know AFRs again :D
that's a great sheet covers everything :ninja: stupid question but how does the dyno know what your tacho is reading. I understand the speed would be easy as the rollers will tell you that but yes bit lost on the rpm.
RPM is generally picked up from 3 different places depending on the type of car.
It will either come from:
A plug lead
Injector
-ve side of coil
For a skyline, will come from the injector easiest way.
Regards,
Cristian
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
