i was a little disappointed.... my car has previously made 174rwKw on the autotech dyno, and nothing has changed since. had a good time though. big thanks to John for organsing the day...
  • Replies 160
Posted Images
Frink,
It has been pointed out to me before that our Dyno reads lower then any other dyno in Canberra.
Ours is the only Mainline dyno here so its hard to compare with another one.
I dont think that our dyno is inacurate but nothing is impossible.
Regards,
Cristian
Frink,
Regards,
Cristian
its all good mate :D. i realise that all dyno's will give you a different reading. i was happy with the way you and your team performed on the day. and your setup is just awesome. big screen, car facing out so you can see the engine working rather than the back-end of the car and a great printout with lots of detail. will be back when i need something like that done again...
Is the correction ratio set near 8% due to the temperature? or the height of Canberra itself? ie around 500-600 metres above sea level?
CeJay,
The correction ratio changes as the weater changes.
So in one day you can see as many as 10 - 15 correction values.
Regards,
Cristian
Dyno readings and power figures are all relative... You can get one result from one dyno and a completely different one from another... What matters is how the car FEELS.
Who cares what the numbers say... I have been trying to get my car perfect on the dyno for months and I have recently realised that they're just numbers... If your car feels quick and responsive and does as much or more than you want it to then thats all that matters.
:(:banana::(:mellow::(
Do you have any idea how hard it is for me not to say anything about what your numbers say and a certain flower? :thanks:
Just had my (delayed) dyno, got 142.2kW and 224Nm, pretty happy with that seeing as I've only done the exhaust. PFC, boost and FMIC on the way!
I would have expected more than that... especially seeing as you have a Power FC installed.
My RB25DET made 186rwkw with only a front mount, exhaust and boost up... Ive seen standard RB25DET's pull 200rwkw with only a front mount, exhaust, PFC and boost turned up... Are you sure its tuned right?
That seems pretty low.... No offence intended.
i think he means he only has an exhaust currently, and the the PFC, intercooler and Boost will be done in the near future.
so 142rwkw for stock car with an exhaust is pretty good.
Hah yeah I, PFC isn't in yet :) I'm hoping for 180-190 when the PFC/FMIC/boost+ are in.
Baconer: Yep, saw yours pull similar. I've got a lightened flywheel which probably comes into play. Can't think of anything else it would be if yours is as stock as mine. Guessing you might have a FMIC or something I don't. Either way, close enough :rant:
Edited by sl33py
nope mines stock except for turboback exhaust aswell. Will be interesting to see how your car goes after the mods, will give me a basis of what i should do to get similar power (aka, you do all the work and ill copy you later) :)
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
