hi guys thort id try and pick your brains and see if anyone knows much about air con in these skylines.
when I change from the different settings from demister to feet it makes a click click clack noise from somewhere it sounds somewhere at the top of the dash, I have done a search and apparently it is the plastic cogs on the stepper motors, whats involved in getting these stepper motors out??
Also when switching the climate control it is only cold at 18 and the rest are all warm which is annoying, I have done a diagnostics on it and its coming up with
outside air sensor
inside air sensor
sunload sensor (not sure if this would be faulty because I did the test when it was in my garage.)
How can I find the other 2 sensors? and how can I test them?
Any help would be much appreciated, im sure with all the r33's around theres gota be someone whos had these probs aswell.
https://www.sau.com.au/forums/topic/181553-air-con-probs-r33/
It seems that I have the same problem as you. (you can only turn the stereo up to cover it for so long lol)
Im really keen to find out what is involved in getting to the controls.
Somone here had an english workshop manual maybe there might be some help in there??
Jason.
should be the same for r33 in my car the sensor in a little vent to the left of the steering wheel was disconnected which caused problem u described, could be any of the sensors thou....cold air at 18....anything more it went hot. also when u did the diagnostic did it tell u the temp the sensors were reading were they all similar? because my the faulty sensor in mine was given a really different reading......as for the noise i get that too is abit annoying!
Edited by rgr34
I've found I can stop the clicking if I leave the air on face and feet all the time... then it doesn't click when I start the car. It will still click when I turn on the climate control or change the direction of the air, but by then the stereo is on. Bloody annoying but from what I understand its a whole days work removing the entire dash to fix it then put the dash back together. maybe I'll fix it one day... maybe
The sound you guys/girls (if any) is the sound of the gears slipping on each other when you're trying to change the direction. The gears have probably just worn out over time. To change it, I think you have to take out the whole dash to get to the heater core.
I dont mind doing that as long as I know what Im doing once I get it off and can get the parts to replace them.
Not looking forward to pulling off dash and then having to put it back together if I cannot find out what the problem is or source parts.
I'm not positive that your problem is the gears, but I heard it was common problem on the 33's heating system. I'm just giving you ideas mate. I don't want you to rip out the dash and found nothing wrong inside. Taking the dash out seems like a huge job.
that sounds like my issue. the gears, mine only does it for 5 seconds when it turns on or off.. dash is easy. just need to find the gear thats clicking//:action-smiley-069:
Hey mate thanks for that, have the cover off and the only thing that leads to that vent is a pipe.... so does this mean the sensor is missing or is it in a different place?
hey mate in my r34 there is the plastic pipe u describe and another plug for sensor connected in........ someone with a r33 needs to confirm its the same.......i would imagine it is thou....the plastic pipe connects to the back of the unit and the from memory the plug is on the side u see anything like that?
same issue as above, but only for around 6 clicks, but then if you listen closely espcially in the mornings i can hear like "water running down the sink" sound coming from the engine bay???? could be related to the air con issue im not sure. wondering if anyone has heard a simular thing??
guys it it the motor on which switches the vent over, mine does the same thing but I have got a second hand motor and just have to find the time to be stuffed to pull the whole Dash , cluster ...pretty much everything aroundthe dash to get to the motor.
5-6 hour job I believe....I will get around to it some day......car is only driven on the weekends anyway!
Hey thanks man yeah it would be good if someone can confirm if there is a sensor there because that must be the climate control problem if it is missing, seems abit werd tho because there are no wires there or anything.
cheers.
Some say that it'll take about 6 hours, some say that if you know what you're doing, it'll only take 1 hour. I think it's best to get someone who's taken out the dash before to help save some time.
Yes it does take 4-5 hours..
Its a big job taking the WHOLE dash out..
thats right, you gotta take everything off..
This guy had pics up here on how to take the dash out: http://gtr.ferni.net/misc/dash_removal/
BUt seems like the link isnt work anymore :(
"ferni"-- hmm that name sounds familar.. im pretty sure hes on this website..
hope he sees this
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
