i currently own a 33 gtst, im only 18 and it costs me 4k a year for full comp insurance, and have always loved the look of the stagea's, and wondering if i was to off load the skyline and jump in a nice suttle stagea could i expect to pay less insurance you think? it really is an option i am looking at... nothin makes go weak at the knee's more than a tuff wagon
https://www.sau.com.au/forums/topic/181674-insurance/
agrees with Micah.
you will definetely pay less with a stagea. Try shannon insurance and look for xavier or nick or vince. I think they came to the SAU meeting and was introduced in the meeting. I assume they will look after you . Tell them you are from SAU though.
https://www.sau.com.au/forums/topic/181674-insurance/#findComment-3299412
yeah thats my car in the avatar, such a huge decision to make. love the idea of the stag, such a sleeper, and 4k insurance is a burn in the pocket at 19(just realised im 19, birthday was last week) so you guys mite just be lookin at the next new stag owner
https://www.sau.com.au/forums/topic/181674-insurance/#findComment-3299888
being that age with shannons, I highly doubt they'll do anything for you.
most companies that know what stageas are, are classfied as same as skylines
so no, not cheaper in most cases.
my suggestion - go third party Fire and theft with just cars
https://www.sau.com.au/forums/topic/181674-insurance/#findComment-3303575
i am 34 and insured thru shannons for both my aprilia and my stagea on rating one for life and dunno what my no claim bonus is? never asked.
combined insurance policy for both vehicles is $1845/year
cheers oxford.
oh by the way i am in ballarat too so ifn you wanna have a look at my stag you are welcome to have a sit in it etc. and can take ya for a spin as well if you want, you may have seen my car round town a bit, its the bright yellow one from premier piercing and tattooing.
https://www.sau.com.au/forums/topic/181674-insurance/#findComment-3303636
why are u paying 4k a yr for insurance?
at the start of the yr i was 18 and had no insurance history and i payed $2200 premium for a 1997 s2 gtst with mild mods and agreed value of 18k
only thing i can think of is u live in a suburb that has a high rate of thief
https://www.sau.com.au/forums/topic/181674-insurance/#findComment-3303662
