I've read a few books about driving lately as well as gotten advice from many about improving driving skills. Everyone suggests that a key high performance driving skill is learning to heel-toe on downshifts. What I have seen mixed comments about if you should single or double clutch when you downshift. What do you guys do?
https://www.sau.com.au/forums/topic/181699-downshifting/
I only double clutch from 3rd into 2nd. I'm not sure why that is; I think its just force of habit. There's no mechanical reason for me to do so. I think even if I go from 4th to 2nd I'll still do a single clutch; definitely from 4th to 3rd is a single clutch manouvre.
I know that if I want to grab 1st from 2nd while on the move I need to double clutch; a simple heel-toe still locks me out of 1st.
Heel-toeing helps your rev match, which is good for avoiding compression locking when decellerating while not having to faff about with easing the clutch in. When you're driving close to the limits, doing stuff that stops the car from upsetting its balance is a good thing.
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3299713
Double clutching is one of those skills that once you have mastered just comes naturally every time that you change gears. It does put less stress on your gearbox and makes the shift smoother.
If you have a GTS-T then a simple mod is to install a GTR accelerator pedal. It is simple to install and has an extension out on the left side to make it easier to heel toe. These only cost about $20 and make heel toeing so much easier.
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3299831
Double clutching ie; clutch, shift to neutral, lift foot off clutch, clutch again, shift into gear?
Besides protecting your gearbox, I dont see much more point to it?
As one writer said after a while it simply becomes habit.
When you consider the correct technique for tarmac driving and cornering being to brake first then down change the double clutch down change makes no time difference whatsoever. The benefits are a smoother ride, less wear and tear on the gearbox, no compression lock. Certainly for street driving it is probably a marginal call doubling from 4th to 3rd but always 3rd to 2nd or 4th to 2nd.
In racing applications you would never think of not doubling and in fact is an important part of passing the observed driving test to gain a racing licence. After that you start to play with flat changing and left foot braking...a whole new tutorial on the left foot braking pros and cons.
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3300415
To be honest Im not sure myself... I think I use a mix of single and double clutching when Im heel-toe downshifting when driving spiritedly...
If its a normal downshift I will almost always double clutch. But yeah, when giving it a bit of stick you dont always have a lot of time (obviously) so sometimes I think I just single clutch?
One thing Ive noticed watching the pedal cam in Japanese clips (option, BM etc), is that a lot of drivers in those clips only single clutch when downshifting.
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3300433
I've been trying to double clutch all the time on the street just to ingrain the habit, but didn't really know if there was a reason to single or double. I've had a couple of ocassion on the track where I've definately upset the balance of the car downshifting without doing it. Spun once.
I have a GTR but installed Razo pedals anyway as they are height & width adjustable so it is easier to roll over on them to blip the accelerator.
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3300631
you learn something new everyday.
will be getting one soon for my GTST
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3300635
The point of heel and toeing is to maintain braking while changing down ie your right foot works both the accelerator and the brake at the same time. With a syncromesh gearbox I can't see the point in double declutching, you can still match revs with speed without it. For racing it would be just too slow anyway. Well it should be :thumbsup:
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3301307
I'm with him. What's the point of doubling?
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3301587
yeah in practice there's no real point double clutching, I guess in theory it saves your synchros a bit - its heal toeing/rev matching that is the important skill.
but 260DET....its not really slower, even with double clutching there are almost no places where the time to change down gears is longer than you are on the brakes anyway.
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3301802
I think a few people are confusing double clutching and heel-toeing.
in a synchro box there is no need to double clutch. rev matching with heel-toe is all you need to do. if you do that properly, the synchros get a harder time up-shifting on the track.
I'm with 260DET. definitely not enough time to double clutch downshift at places like Mt Cotton hillclimb. And even if there is, by the time you've done the second clutching while braking hard, your road speed will have changed so much it was all to no avail anyway.
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3303090
^ Exactly my thoughts.
Quiet Achiever: The benefits you stated can be achieved through rev matching alone and therefore theres no need to double clutch?
I can understand it being a habit, but besides that i stand by my point.
https://www.sau.com.au/forums/topic/181699-downshifting/#findComment-3303149
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
