hey everyone.
installed a amp into my 33. its only an old soundstream so nothing flash. the weird thing is the only way to get power to it is bridge a small piece of wire from the power terminal to the remote terminal on it. now i thought that should give it constant power but it doesnt. it just operates normal. as in when i turn the deck off the power goes off. never had this problem before when installing in other cars. i dont have a problem with running it like that it just seems a little weird! any ideas??
https://www.sau.com.au/forums/topic/181833-amp-wiring/
You've sourced power from an accesories line?
Also, that doesn't sound like a problem... That sounds like what it is supposed to do if installed correctly... Why not just run with it? :action-smiley-069:
i sourced power from blue and white wire on the back of my pioneer deck. but its just strange how i have 2 have that piece of wire running from power terminal to the remote terminal. oh well guess ill just go with that :D
https://www.sau.com.au/forums/topic/181833-amp-wiring/#findComment-3302839
i sourced power from blue and white wire on the back of my pioneer deck. but its just strange how i have 2 have that piece of wire running from power terminal to the remote terminal. oh well guess ill just go with that :action-smiley-069:
ummm Your blue and white wire is your switch wire for the amp... Its supposed to go to the amp to tell it to turn on...
Are you saying that you are also powering the amp with this?
https://www.sau.com.au/forums/topic/181833-amp-wiring/#findComment-3302996
i got the remote cable which connects to the back of cd player. positive cable goes 2 battery. and the earth connected 2 bolt. the only way for the amp 2 work is have another small piece of wire from the power terminal to the remote terminal. seems very weird 2 me!
https://www.sau.com.au/forums/topic/181833-amp-wiring/#findComment-3304351
It sounds a lot like either:
Your remote wire is dead... so bridging it turns the amp on... but this would keep the amp on indefinitely.
More likely, as guessed, you are running the amp off the remote wire, and the power cable you're using to the battery is just not connected properly. It should have an inline fuse (ideally). If it has one, check it.
Otherwise, get a multimeter and test the continuity from the battery positive terminal to the amp positive terminal without the bridging wire.
https://www.sau.com.au/forums/topic/181833-amp-wiring/#findComment-3308352
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
