In the words of the black knight "can't we all just get along" ha ha.
hey man no peer pressure here like i said its your call, best plan, save some money, do your coil packs and get it tuned when you have the money, jsut means youll have to live with it a bit longer and baby it.
moving on
whats happening tonight? anybody appart from pinksta (welcome back) going to be out tonight?? im still waiting on parts :) so no hard driving for me, just put around...
Guest Rexlr8
I'll be defently at the drag strip!
I changed my G-box oil the other night. Thanks to ryan mind you.
I had bad crunching from 3rd to 4th. Anything after 3,500rpm it crunched. And likewise from 4th to 5th.
That was geniune ( Cant spell for shit ) subaru gbox oil in there with nulon addative. Worked for a bit. Survived a day on the dyno.
But it just grew worse. I brought some Redline Gearbox oil. Type: Lightweight shockproof. Aka, smurfs blood. Normally around $220 delivered for 3.8lts i got mine for $111.50 for 3.8ltrs.
www.performancelub.com Check it out peoples. Great oils and fast Delivery. 3 working days to NT to my door.
Anyway. I put it in, as soon as everything was warmed up. Flogging time!!! Every gear much more direct with no sign of crunching through 1st to 3rd... Now... test time... Gave it hell to top of 3rd and changed.... Guess what. No damn crunch! I'll be happy to prove it too people too! You could hear the crunch with original oil over my sterio... No shit. The oil has a much more direct feel to it and alot smoother! Bad thing is.. Theres alot of downsides. You have to make sure you can get every last drop of your old oil out. I let mine sit for the whole night and most of the day. She was empty! Other wise it mixes and turns to Jelly... No good. And... you cant go from redline back to another brand without flushing your box many times with cheap cheap oil. It mixes with the new oil and makes it bad. And can actually fail and destroy your box. But defently something for you boys to look at. Also... It says on the bottle 500,000k life span... If you drive a damn golf buggy. For most wrxs it's between 10-15ks max.. But thats awd and hard launching. All your boxes are stronger then mine so the effect's will be greater with the oil i'd imagine. And life span alot better. Check the threads here about REDLINE. Some hate it, some love it. Im a lover :P
Harold at that website is awsome. He just rose his price's tho. Only by 5-10$ tho. Im really happy about it.
Anyway. Enough Late night tele marketing. Now remember, if you buy 1, you get 1 absolutly free. And if you use your credit card. I'll throw a smack in the head free for not doing it sooner!
Good luck at the dyno
hey guys, good turnout at the drags lucky no big problems today.
im putting some of the videos from the day up on u tube if people want to check them out, i also have the movies from the dyno night if anyone want them i got them on disk.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
