ok people theres goin to be a cruz on 16th of november to jims place or ross river take ur pic one with most vote wins so get the day off and cum for a drive
and were trying to get dr drift to alice to tune cars but we need at least 8 cars so yea he will use street torqes dyno hopefully if dallas lets him be good to get our cars tuned here to this climate
and make sure every one rocks up at the street meet on 2nd november to act mad and waste sum tyers and have a bit of fun CATCH UUUUUUUUP
Hey guys count me in for the cruise i dont care where, ill have my car up here by then as long as nothing goes wrong so ill get it out and come for a drive..
as for the strip ill come and watch but she wont be getting flogged lmao. see yas there
yo guys prob wont be up for the street meet much as i would luv 2 burn sum rubber but prob up for cruise on 16th of november i vote Ross River...
Yeah car is nearly the just got to get a dump pipe for the turbo before we can drop the motor in then yeah will also hopefully be gettin an intercooler by the end of november so yeah should see yas out on de road soon ay.
good stuff jason :/
Hey guys speaking of long gears anyone have any idea what i might want to change the diff in the xr to once i start modding? i've heard the xr8 difs run pretty well cause they slightly longer???
anyone got some other suggestions?
everyone playing tomorrow night?
probab;y just get different ratio in that diff for the falcon. Buy a good centre and some 3.7 or 3.9 gears. Not much point in have heaps of top end speed if you never use it anyway. As long as it still gets good fuel economy on the highway then it don't matter.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
