ok people theres goin to be a cruz on 16th of november to jims place or ross river take ur pic one with most vote wins so get the day off and cum for a drive
and were trying to get dr drift to alice to tune cars but we need at least 8 cars so yea he will use street torqes dyno hopefully if dallas lets him be good to get our cars tuned here to this climate
and make sure every one rocks up at the street meet on 2nd november to act mad and waste sum tyers and have a bit of fun CATCH UUUUUUUUP
Hey guys count me in for the cruise i dont care where, ill have my car up here by then as long as nothing goes wrong so ill get it out and come for a drive..
as for the strip ill come and watch but she wont be getting flogged lmao. see yas there
yo guys prob wont be up for the street meet much as i would luv 2 burn sum rubber but prob up for cruise on 16th of november i vote Ross River...
Yeah car is nearly the just got to get a dump pipe for the turbo before we can drop the motor in then yeah will also hopefully be gettin an intercooler by the end of november so yeah should see yas out on de road soon ay.
good stuff jason :/
Hey guys speaking of long gears anyone have any idea what i might want to change the diff in the xr to once i start modding? i've heard the xr8 difs run pretty well cause they slightly longer???
anyone got some other suggestions?
everyone playing tomorrow night?
probab;y just get different ratio in that diff for the falcon. Buy a good centre and some 3.7 or 3.9 gears. Not much point in have heaps of top end speed if you never use it anyway. As long as it still gets good fuel economy on the highway then it don't matter.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
