Not sure about the autobarn polishers, but my mate bought one from supercrap.
He covered his car in polish by hand and turned it on, his new toy. It went bang and set off the trip switch. Farken funny he then had to polish the car by hand and by this time the polish was farken hard to get off.
But with those things they all have a warranty so you cant go wrong really.
Edited by subzeroR33
ive used one,, but i prefer to do it all by hand... yes its hard work, but i find i get a much much better result doing it by hand..
in saying that though, i use my electric polisher on my head lights with the meguirs plasticx stuff and brings them up good :rolleyes:
i got one from supercheap and it was crap as - luckily i bought it for dad for fathers day not for myself
so yeah - i have one and its so crap i still do it by hand - im sure good ones that would properly would be awesome
Try plugging it in Zennon, You will be amazed at the diference it makes. ;)
Hey fellas..
well got bored today after my lecture. so i went home.. and washed my 180.. then got out my new polisher.. and gave her a go..
i used armour all wash and wax...(will switch soon its shit!!)
aion chamios
supertool polisher
Mothers cleaning wax.. california gold label.?
armour all super soft polishing cloth
took 2 hours.. and very happy with results ;)
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
