I'm about ready to go to an auto-electrican, so if anyone can help diagnose and solve my problem, i'll forward $50 your way. I studied a couple years of electrical engineering, and am handy with a multimeter, so not a complete newbie!
My parkers circuit in my 33 keeps blowing fuses under the bonnet, from what i can work out, the following source power through that particular fuse:
- front parkers
- rear tail light parkers
- number plate light
- dash illumination
- radio illumination wire
- beeper under dash when door is open, or lights left on
- somehow the interior light is also effected, as now when it is set to door, it stays on all the time - and with the lights turned on, it is only half-brightness which is weird behaviour.
I've tried to inspect front parker globes, numberplate light, no visual shorts. Removed dash cluster, still blowing fuses. Checked radio illumination wire, taped up well. Checked one brake light, visually ok. Hard to check the other light due to my boot install. Checked the resistance accross the two wires going to the unplugged numberplate light , approx 0.5 Ohms indicating a short somewhere. Unplugged column switch, still 0.5 Ohms accross numberplate light, so not the actual switching mechanism.
When i put a new fuse in, my beeper works ok, and key ignition lights up, as soon as i turn on parkers, fuse blows.
I'm happy to cut the relevant wire along the side of the car, to help isolate the problem to the front/rear end of the car, not sure on wiring colours though.
Any smart auto-electricans who can provide assistance?????
How long have you had the problem? What have you done recently that might have upset the wiring?
Remove ALL the globes (or disconnect the wire to the globe), including instrument cluster. Now add them back one at a time, until you find a combo that blows the fuse.
So if you're sure there's a short... I guess it's a matter of finding out where it is?
If you go to continuity mode, and test the positive of a globe socket to the chassis of the car... does it show a short? I'm not sure what kind of resistance between + and - you should normally see... so that's the way I generally test. A bad earth shows up with the above method also. (as you probably know)
Failing that, could you perhaps test from one terminal of the fuse holder to the rear plate (with very long extension cables on the multimeter) with the multimeter set to "volts"? That would show how much, if any, voltage is being dropped across that piece of wire. I guess if that works as a good test, you could then try each suspect point until you narrow down the cable that's shorting?
hey fellas,
man i had d exact same problem i got a gtst 97 s2, i got an auto electician to do it, took about an hr, it is defiently a short. my one was a short from the wires coming outta the fog lights, or around that area... sorry its not much help man but i remmember the electrician put this thing that has a light bulb connected to it onto the fuse the light stayed on he kept putting the other end onto different wire connections untill the light went out he disconnected it put in a new fuse and it never blew.
did you install anything lately ?? car audio, amp etc ? Last time mine was the F*^%$$^% audio tech accidentally wire up the ground wire of the audio to the dash light +ve. So every time i turn on my lights the fuse blown.. it took me 2 hrs to find it. :P
  • 4 weeks later...
Hello,
I have exactly the same problem. Has anyone found the solution?
My R33 had some aftermarket fog lights fitted whenI bought the car. Someone recently stole them off my car. I took out all the wiring relating to the fog lights. The fuse still keeps blowing when I turn on my lights.
Any help is appreciated!
Luke
  • 1 year later...
Hi guys ok i am having the same problem here my rear parkers, dash light nothing is working everytime i put a new fuse in and turn the lights on it blows. Have checked everything under the sun and still can not find the problem... can any one PLEASE help its mad because i cant drive my car at night!!!
PLEASE HELP
I had a problem like this once in my Falcon. Parker lights, interior lights, dash lights, stop tails, and indicators would all blow constantly both globes and fuses. Turned out to be the indicator flasher box in the fuse panel of all things (the thing that makes the tic tok tic tok) maybe try that, they are about $15 couldn't hurt I guess :)
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
