Skyline newbie here again, i saw a r32 gts-4 for sale today and it got my attention. i understand that they are rb20 powered and all wheel drive. i would like to know how many parts they share with the GTR or are they literally a 4wd GTST?
https://www.sau.com.au/forums/topic/182206-r32-gts-4/
Well, as a current owner of one, I thought I'd comment:
The R32 GTS-4 is a great machine, but it's a compromise.
It has the GTR suspension, AWD, and can be modded to use the same calipers (from what I understand anyway)
apart from that it's really a GTS-T.
I chose a GTS-4 due to the fact that I love AWD, but didn't want the upkeep of a GTR.
You can easily install a 2WD switch, but the added weight of the AWD system mean it will not be as fast on the quarter mile as a GTS-T, but it'll kill it in the twisties.
The GTR will naturally own the gts-4, but then again, it's double the price.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3308932
all the running gear is the same as the GTR as far as i know.
just the motor/gearbox is rb20 spec.
definitely not a 'mini godzilla' though.
Yeah I think the GTS-4's gearbox has shorter gears for better acceleration. I think GTR owners who are into drag racing often put the GTS-4 boxes in because they're better suited to quarter mile.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3309002
No, the DIFFS are shorter (4.375 vs GT-R's 4.111)
I call it a "baby Godzilla" - all that is missing is 600cc and a turbo! Many of the mechanicals are interchangeable with the GT-R.
But with a RB25DET ... now that's another story!
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3309629
yeah this is what i was thinking , half the price of a gtr, a bit lighter, understated styling and lower geared. chuck in a boosted 25 and we're laughing
I guess 1450kg is a "bit" lighter than the GTR's 1460kg
I've had one.
unless it has something other than an RB20 in it, don't bother.
just not enough torque to do anything right.
I knew that before buying it and had planned to build an RB30/25 for it..
things changed, I sold it.
Stag engines aren't that easy to come by.
No you can't just use an RB25 out of any R33/34 skyline.
You can use an RB26 no worries.
but then after you've spent minimum $4K for engine and another $2K for the install and getting it running, you now have a car that is the same price as a GTR of the same vintage would have been and still NO GTR.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3310628
yeah i guess your right, im just trying to think outside the box. ;), i have seen a few stagea cuts forsale latley. im very suprised that they are similar weight to the gtr , they are very heavy for a small car. to heavy for a twenty for sure
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3311564
Are you from America? How can you call a Stagea a "small car" ;)
Anyway, you also mentioned looking for a Stagea engine..... unless I am mistaken they have an rb25det just like an r33 gts-t? What is the difference?
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3311610
i think hes talking about the gts4 being heavy for a small car.
the stageas are 4wd drive i think? the rb25 in them would have the front drive shafts/sump that would suit the gts4s. an rb25 from an r33 would need a modified sump and bits to go with it. that what i *think* at least.
i own a gts4, also. good car. great in the wet. sure not the quickest, but like the dude up top said its a compromise. even then, its fine to drive daily and unless youre really looking to have a race every set of lights does it really matter being that much slower? i like my 4wd.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3311627
Stagea 4WD
Engine swap
Thought that was pretty simple to understand?
Either way i love my GTS4 and dont plan on doing an RB25 or 26 swap at all... Too in love with my RB20!
Should be making about 250-260rwkw soon and im really looking forward to seeing what the car can do then!
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3311632
Stagea 4WD
Engine swap
ill tell you right now what it'll do. it'll munch right through your gearbox if its standard.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3311681
How many R32 GTS4 gearboxes have you broken?
RIPZ in NZ have these cars in the 10's using rb30/25 and stock gearbox and diffs.
that requires ALOT more power than 260rwkw.
and alot more torque than 4 rb20's put together.
they are not like a GTST rb20 gearbox.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3313305
