Can anyone with a Series 2 with a boost gauge take a picture of the engine bay where the vacuum hose is cut for the t-piece connection please. Installing mine this weekend (today!) and would like to be sure before i start slicing and dicing!
Thanks!
EDIT: Ok, now I'm trying to wire it to the lights, but only when i turn the spots on.
Edited by webng
https://www.sau.com.au/forums/topic/182260-boost-gauge-installation/
There is a spare nipple on the back of the inlet plenum (on the S1, probably on the S2 as well?) That is where mine is attached. There is one at the font too but that is further away from the gauge of course...
Thanks for that. I ended up putting it somewhere else, with advice from a mate whose gauge was conected the same way. But where i have it at the moment doesn't show back pressure vacuum (before throttle body or something), only boost, which is accurate (7/8psi). I'll move it to the hose from the plenum instead, now i know that's better.
Can anyone explain to me how the back pressure vacuum works? And why i need to see it on the gauge. Less vacuum is better or worse?
The hose that came with the Autometer gauge (hard white plastic one) wont go over the extra nipple from the plenum, it's a pretty small internal diameter. Is there some rubber attachment I can get that will connect the 2?
Anyone with the back pressure explanation?
Thanks.
Thanks.
Cheap quick fix is to use some 3-4mm vacuum hose about 5cm long
Push it over the nipple on the plenum and push the hard plastic autometer hose in the end of the vacuum hose. Fix with cable ties
Ahhh... good idea, might look dodge though hey. Any idea if the gauge connected to that nipple will show vac as well?
If you do not want to see the join, run the rubber hose back to the firewall, and then the lastic hose from there
If you are connectiong to a nipple or hose from the inlet plenum, ie after the throttle body, then you will see vacuum.
No vacuum is not surplus air from the turbo,
Vacuum is how a normally aspirated engine works, the piston pulling down in the cylinder draws the air/fuel in - like a vacuum.
The turbo helps this along be forcing (forced induction) more air into the combustion chamber.
These links might help make things a little clearer:
http://auto.howstuffworks.com/turbo.htm
http://auto.howstuffworks.com/engine7.htm
Couldn't find anything totally vacuum specific but I'm sure it is in there somewhere or someone else will have a better answer for you.
Cheers
Luke
Edited by munchstagea
yes. yes it will. :rofl:
Thanks for the replies guys. Now I'm trying to wire it to the lights, but only when i turn the spots on, so i can choose to have it off even with the main lights on. I tried to find the wiring under the dash/steering wheel but it all looks pretty crazy under there. Should I remove the whole steering wheel to have a look?
Another option is to wire it to the old Japanese card/toll reader thingy and put a switch there to turn the boost light on and off. Don't really want it on all the time, prolly blow te bulb quick smart.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
