Everything is possible, but at the end of the day why would you?
It would make the car so nose heavy that the only good thing it would be useful for is drag racing (i.e. Going straight) By the time you dump a whole bunch of money into the project, It would have been cheaper either to buy a GTR, or modify the krap outta the SR. But at the end of the day its you car and your money.
Speed costs money, how fast do you want to go?
Originally posted by RESESPIECES05
Your wrong about the nose being too heavy. Cause over here in america were starting to do the swaps. There is only about a 70 pound difference. Plus you get mid 13's just stock.
JDM spec S15's are only a tenth or two off from mid 13 sec passes as well.
i hear that advan's charge 20,000AUD for the conversion.
you can do alot of things to an sr20 with that money.
Well, another thing that's good about the skyline engine is that it provides more low down torque because of the bigger displacement. Also, you can fit a larger turbo on it and it won't be no where near as laggy as a 2L SR20.
But really, it's gonna cost so much to buy and install an RB26 in an s15. I really don't think it's worth it unless you have loads of cash to blow. Nonetheless, an RB26 s15 would fly! :)
How many people have skyline engines in an s15? And why did they do it?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
