  • Replies 71
Originally posted by Strich9ine
smaller boobies = fit in mouth.... all the rest is wasted :)
do they have blue feet? only bird boobies I know...
hang on... there is no waste with boobies. they are bigger the better ;)
and pauly have fun... checked yor post whore status lately? not going good at all
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
