I just about passed with a FULL 3.5inch exhaust today (95db)
Minor alteration in a couple places and i'll get under the limit no problem in the world, know exactly what i need to do, and be legal doing it.
Goes to show, a properly engineered exhaust can still flow for 400rwkw, and pass noise testing without even having to worry ;)
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318745
what exhaust do you have? what do you plan doing to modify for epa test?
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318816
I had a 100% custom made one ;)
Put it this way, an exhaust made to PASS EPA isnt cheap, and im not talking $1500 here either.
I've paid some damn good money to have it made, and the results speak for themselves. Even the EPA guy doing the test was highly surprised at how close it was to legal for such a free flowing system (will flow 400rwkw no worries if it needed to do so).
Considering all the crappy Jap systems that he would see on a daily basis, my car was a very very big surprise with results it returned.
Some people have said that cost was too much, but IMO it far outweighs the costs of constant defects and EPA's... which over the years have cost me a fortune alone.
Minor alteration to mufflers and it will be fine, will pass without even thinking about it.
That was running a CAT and all the other bizzo aswell.
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318863
Crappy Jap systems? Settle down...i'm sure yours is very nice but calling the jap systems rubbish because they don't pass an AUSTRALIAN noise limit is a bit much....
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318949
Well them not passing isnt my problem is it? ;)
The laws are here, you comply the car to AUS Import Regulations and other AUS laws. So why not the noise laws too?
Its not really a 'bit much', there is a fair bit of crap on the market.
Why pay $$$ for a Jap exhaust if it doesnt even come close to passing? I dont really see the point, and hence ive always had locally produced exhausts :)
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318968
how can you call a japanese exhaust system crap because it doesnt pass an australian noise limit...thats 1 of the stupidest things ive ever heard.
not to mention the fact that plenty of jap systems can pass the australian noise limit if thats what you want, without being modified and costing less than $1500.
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318982
They might pass, but will they flow for the power is the question :D
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3319298
Mate you could always just make up a small plate with about an inch opening or so depending on what you need, and just bolt that up between where the cat and catback bolt up, easy to take off after just make sure its not too obvious as in nsw they lift the car up and do a thorough check with pics, best way to hide these things is get some exhaust sealer from supercheap and cover the joints up...
that or invest in an Apexi EVC like i have, saves ALOT of hassles!
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3319532
Goes to show, a properly engineered exhaust can still flow for 400rwkw, and pass noise testing without even having to worry :bunny:
yeah, what needs doing? will it still be full 3.5in?
mine is quiet but still a little loud (it's probably more or less exactly like yours, except for differences in the under body shape :)
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3320170
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
