I just about passed with a FULL 3.5inch exhaust today (95db)
Minor alteration in a couple places and i'll get under the limit no problem in the world, know exactly what i need to do, and be legal doing it.
Goes to show, a properly engineered exhaust can still flow for 400rwkw, and pass noise testing without even having to worry ;)
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318745
what exhaust do you have? what do you plan doing to modify for epa test?
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318816
I had a 100% custom made one ;)
Put it this way, an exhaust made to PASS EPA isnt cheap, and im not talking $1500 here either.
I've paid some damn good money to have it made, and the results speak for themselves. Even the EPA guy doing the test was highly surprised at how close it was to legal for such a free flowing system (will flow 400rwkw no worries if it needed to do so).
Considering all the crappy Jap systems that he would see on a daily basis, my car was a very very big surprise with results it returned.
Some people have said that cost was too much, but IMO it far outweighs the costs of constant defects and EPA's... which over the years have cost me a fortune alone.
Minor alteration to mufflers and it will be fine, will pass without even thinking about it.
That was running a CAT and all the other bizzo aswell.
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318863
Crappy Jap systems? Settle down...i'm sure yours is very nice but calling the jap systems rubbish because they don't pass an AUSTRALIAN noise limit is a bit much....
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318949
Well them not passing isnt my problem is it? ;)
The laws are here, you comply the car to AUS Import Regulations and other AUS laws. So why not the noise laws too?
Its not really a 'bit much', there is a fair bit of crap on the market.
Why pay $$$ for a Jap exhaust if it doesnt even come close to passing? I dont really see the point, and hence ive always had locally produced exhausts :)
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318968
how can you call a japanese exhaust system crap because it doesnt pass an australian noise limit...thats 1 of the stupidest things ive ever heard.
not to mention the fact that plenty of jap systems can pass the australian noise limit if thats what you want, without being modified and costing less than $1500.
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3318982
They might pass, but will they flow for the power is the question :D
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3319298
Mate you could always just make up a small plate with about an inch opening or so depending on what you need, and just bolt that up between where the cat and catback bolt up, easy to take off after just make sure its not too obvious as in nsw they lift the car up and do a thorough check with pics, best way to hide these things is get some exhaust sealer from supercheap and cover the joints up...
that or invest in an Apexi EVC like i have, saves ALOT of hassles!
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3319532
Goes to show, a properly engineered exhaust can still flow for 400rwkw, and pass noise testing without even having to worry :bunny:
yeah, what needs doing? will it still be full 3.5in?
mine is quiet but still a little loud (it's probably more or less exactly like yours, except for differences in the under body shape :)
https://www.sau.com.au/forums/topic/182460-epa-fun/page/2/#findComment-3320170
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
