Hey
Recently been attempting to rectify an issue with the heating in my R32.
It seems to not adjust temperature from hot to cold, or vise versa, it just holds one constant temperature no matter what the unit is set on.
I ran it in that diagnostics mode and didn't mean shit to me, so I gave up.
I did a little test yesterday, I started off by bleeding the heating system and thats all fine, water is flowing fine through there.
I then checked the radiator hoses to see if they where the correct temperatures, that was fine, bottom one cold, top one hot, and hot water is feeding through under the manifold through that heater pipe.
BUT
The heater hoses on he firewall are dead cold. They have water in them it feels like, but it is not warm. I'm assuming thats why my heating is not working, but why isn't the hot water flowing into the heater core is my question?
I tried it when the car was cold, idled till it was at operating temperature, even drove it hard so it was well into operating temperature and still the heater hoses where cold.
Any help would be appreciated.
Thanks,
Abu
https://www.sau.com.au/forums/topic/182501-r32-heating-issue/
Sounds like a problem I was have at the start of the year. There's a motor near the back of your dash which controls the hot/cold, but before you go and check to see whether it's stuffed, try holding down the 'heat' button for like 10-15secs or until the sign 'FH' appears. If you still get no change in temperature, it's your valve.
Let me know.
Let me know.
Hey Adam!
Tried that FH trick last time, unfortunately no change. What does this mean?
Thanks,
Abu
It could be your connecting rod which has disconnected off the hot/cold flap.
Common problem on the skylines and an easy fix.
Look at the footwell of the front passenger area.
Look up under the dash (behind the headunit)
There should be a metal threaded rod which moves side to side. This should be attached to a plastic clip.
Where abouts do you live again?
I can drop by and have a look around for ya
Shoot us a PM if you can be stuffed
Hi Patrick
I am from Hallam man, probably about 20 - 30 minutes from you.
Connecting rod hey, I will have to take a look when I get back from work, if I have any issues I will send you a PM.
Do you I have to pull the centre console surround out and the headunit etc? Or can I just see up from the foot well? Cant picture it right now in my head, but will make more sense when I take a look at it when I get home.
I get what you mean though.
Thanks,
Abu
Edited by abu
You'll be able to see the motor from the passangers foot well. It should be at the back of where the headunit and that would be. Depending on where Pat lives, I can check it out for you. I'm in the Dandenong area. :laugh:
Oh ok mad. Thanks again Adam.
Haven't even bothered to look yet, just cant be stuffed doing anything after work.
Will go out soon and have a quick look. Will let you know if I need help, you wouldn't be too far from me.
Thanks! :)
Edited by abu
Just give me a PM if you need any help.
The 'FH' is 'fast hot' or something like that. It should ignore the sensors and just throw out as much hot air as possible, but you said nothing happens so it's probably your motor. Make sure you did this while your car was warm :D
Haha yeah did it when car was warm man.
Will look at the rod today hopefully! Just cbf after work, if not then the weekend.
Any issues I will get you out to come and take a look man :(
Thanks heaps.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
