hey just trying to sell my evo 9 here are some spec's and pics.
06 Evo 9 done 18,000km with log books and service history, im the 1st owner.
always used motul oil and every 5K service oil and filter got renwed, and just recently replaced standard brake fluid with motul racing brake fluid.
2.0-litre 16-valve DOHC intercooled turbocharged MIVEC engine
3 nozzle water spray for intercooler
Engine oil cooler (air-cooled)
6-speed close ratio manual transmission
Full-time 4WD system
Switchable Active Centre Differential (ACD)
Front helical-type limited-slip differential
Rear differential with Super Active Yaw Control (S-AYC)
Sports Anti-lock Braking System (ABS) with Electronic Brakeforce Distribution (EBD)
Front 320mm ventilated disc brakes with 4-pot brake calipers (brembo)
Rear 300mm ventilated disc brakes with 2-pot brake calipers (brembo)
17 x 8.0JJ Enkei light alloy wheels, 235/45R17 93W ADVAN tyres
Recaro full bucket front seats
MOMO leather-wrapped steering wheel
Auto / manual intercooler switch
Driver’s and front passenger’s SRS airbags
Central door locking system, Engine immobiliser
Diamond TRAC security system (GPS tracking)
Ralliart floor mats
Ralliart scuff plates
Tinted windows,paint and interior protection
Full 5 / 10 year Mitsubishi warranty
10 Year road side assist
Full service history
Mods:
Viper 710vx pager alarm system (installed by northfield car sound)
Full custom stero - Alpine touch screen dvd,alpine PDX amps,Alpine Subs,Focal comp Splits and coaxials and stinger wiring and cap (installed by northfield)
Tomei racing dump pipe and font pipe with Trust titanum cat back system with 3" hi flow cat
HKS Induction kit
Greddy B.O.V
Greddy turbo timer
Pivot electronic boost gauge
All standard parts will be given to buyer (standards exhaust,air box and piping,stero)
Performance : 211kw @ all 4 wheels on Godzilla Motorsports dyno runing standard boost
Asking $55,000 ONO as is with 6 months rego and RWC. will consider selling car without audio gear for less :P
Located in Brisbane
For more info
email me on gtr_083 @hotmail.com
call or sms 0432 733 357
thanks
Nick
Edited by GTR_83
https://www.sau.com.au/forums/topic/182564-fs-06-evo-9/
wreckedhead, long time no see. no spamming other peoples for sale threads thanks. you only get one friendly warning like this so please take note of it.
https://www.sau.com.au/forums/topic/182564-fs-06-evo-9/#findComment-3330211
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
