hey guys i gotta s2 r33, i just had to replace all shocks bout 5000kms ago wit KYB exel G's.
im lookin at gettin some lowerd springs cause i wanna elimanate some body roll.
Im lookin at king springs they lower the car to where i want it (front350mm centre wheel to guard and 345mm back)
just wanting some feedback and/or experiences from guys who have these springs.by the way there not the super lows.
https://www.sau.com.au/forums/topic/182823-king-springs-body-roll/
ive got the same KYB's and lowerd kings not the super lows though. not bad i think they are a progressive rate, the coils get tighter closer to the top. comfy to ride on uneven roads and pritty stable during a spirited hills run. i would recommend some decent bump stops too. i also have whiteline adjustable sway/roll bars front/back. seem ok for now.
thanks for the feedback mate the guy at wholesale suspension blacktown told me they were going to be linear springs and the super lows were progressive rate, i haven't seen them yet so im not sure. maybe he has them mixed up.
lol. or i do. i might have super lows then. the springs definatly look progressive rate. thinking about it i actually had to take em back the first time because the inner spring diamiter was too small. shop ordered in some more so this time they might have gotten the super lows..
Anti Roll bars (sway bars) are for reducing body roll. For springs to do it, they would be so heavy your teeth would fall out!
The Elk is correct. If you want handling performance and elimination of body roll get sway bars. These are the single best thing you can do to increase performance of your car. Lowering a car won't reduce body rool - it will simply roll from a lower center or if it rolls too much hit bumpstops (bad thing). If you want to lower it for appearance purposes, thats different.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
