hey guys... i actually was under the name engoR33-300 but somehow forgot my password and things i couldnt get right so im under this one now..... n e ways... i drive a r33 gts-t 93' model with a series 2 engine in her.... my mods are... t04e garret turbo, exractors, 3 1/2 inch exaust full, 38mm external wastegate, hks front mount intercooler, boshe 044 fuel pump, 760cc injectors, turbosmart stage 1 bov, and LT 12 microtech E.C.U..... my problem is that with all these mods... i am running a very very low amount of power.. and wondering what could be holding it back... it ran on the dyno 140rwkw on 5 psi.... i plan to boost it to 12psi.... but is this E.C.U related issues??..
cheers
https://www.sau.com.au/forums/topic/182946-power-issues/
but thats the same thing.... im getting confused here ey...
how can you have extractors on a turbo'd car!! do you mean ur manifold has had its piping "enlarged" ??? do you mean you have a bigger "dump" pipe? or "front" pipe??
extractors are what you call larger exhaust manifolds on NON-turbo cars...eg, all the commodores/fords etc etc. they run from the block down to the cat.
am i gunna get flammed for my confused thoughts here?? or am i not alone? haha
CJ
https://www.sau.com.au/forums/topic/182946-power-issues/#findComment-3319582
Extractors are for NA (naturally aspirated) cars with no turbos. It sits on the head and goes into a dump/front and onto the exhaust.
Turbo cars have a manifold, on which the turbo sits on, and the exhaust sits on the back of the turbo.
For turbo cars you cant get extractors, but you can get different forums of manifold, say tuned length, log style, high mount or low mount log style, high mount or low mount tuned length, and the obvious ones like polished which yeh is obviously just polished lol
Hope that helps a bit.
https://www.sau.com.au/forums/topic/182946-power-issues/#findComment-3319664
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
