Hi all,
I have a couple of retrimmed seats here. They are covered in black suede with red stitching.
They come with universal rails but will need to be modified to fit in a skyline. The have Recaro labels stitched on the bottom of them but I cannot find any other brand markings and they don't look like recaros.
I was going to put them in my 33 but I'm rebulding my motor at the moment and need the funds
Selling as a pair will not seperate (will look better as a pair anyway) $1,000 for the pair
reply here or via pm
ps. the photos don't do them justice, they look as if they have never been sat in, the suede is 100%
Cheers,
Nick
https://www.sau.com.au/forums/topic/182994-black-suede-trimmed-seats-pair/
I have been googling and can't find any recaros that look like these and they definately aren't stock S200 seats... its a mystery...
so I will drop the price to $1000 for the pair... I'm located in Melbourne...
An exhaust shop or anywhere that does fabrication/high quality welding should be able to graft the top of the universal rail onto the bottom of your Nissan one... that's what I was going to do... I have a Nissan rail here you can take with the universal rail and get a quote on the fabrication before you buy the seats (if in Melb)... to see if its worthwhile
these are really nice in the flesh, come check them out!
Cheers,
Nick
definately not genuine recaro's, kinda look sparco shape-ish.
good luck with the sale tho mate.
yeah I don't think so either now (they don't have the usual recaro harness holes)... have changed price to suit but I don't know how to change the thread title?
They have big recaro labels stitched under the bottom of the seat, what a weird thing to do... if you were going to put fake branding on surely you would put it somewhere you can see :D
Do a full edit on the first post and you can change it there :rofl:
Cool seats Nick
hey I think your right, cheers dude!
I just realised I paid too much for these... fantastic considering I bought them from a 'mate'
ah well I'll just put them in the car...
mods can you close this thread please?
look more closely at the JJR seats - yours are different.
the side bolsters on the seat base are Recaro shape - too triangular to be the Sparco style.
the back rest bolsters on yours are more Sparco shape though...
I don't think they're JJR seats....
whatever they are they look NICE.
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
